  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
paralleling variacs & PSU's?
magnet18
Thu May 05 2011, 02:40AM Print
Hi, you might have seen that I just got a power supply, if not heres the pics
1304538807 3766 FT1630 0504111548
1304538807 3766 FT1630 0504111550
It uses a cute little variac inside to control the voltage & current, which is all fine and dandy... but it's limited to 1 A (think I can get it to 2.5 with a single unit, but I want moar power)
So I was wondering, since they should be right in phase with each other if I get two, could I parallel them to double the available current?
Would I need some sort of choke to prevent one from overpowering the other or something, or would a good mechanical connection between the two to keep them at the same voltage work? (I think I can pull that off)
Thoughts?
James
Thu May 05 2011, 05:18PM
You'd need a mechanical connection, otherwise you'll have exactly that problem and things will get really hot.
Honestly you'd be better off just getting a bigger variac and leaving that unit as-is. Lots can be done with a little 1A unit and larger standalone ones aren't too hard to find.
magnet18
Thu May 05 2011, 07:38PM
OK, sounds good... but now I have 3 of these...
If I find some suitable choke transformers I'll mess with it, if not I'll just use them as is, maybe sell one.
