  • Guests: 46
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
How to determine size of coil?
Tim
Mon May 02 2011, 12:56PM Print
Tim Registered Member #3851 Joined: Thu Apr 28 2011, 10:20AM
Hello,
I want to build a system (tube diameter 4inch ) which can launch a ball (diameter 3,5 inch, weight 1,5 pound) to a speed of 3 feet/s at a hight of 1,5 feet.
How can I determine:
- Needed Magnetic force?
- Coil size (how many turns)
- Needed current?
Best Regards,
Tim
Inducktion
Mon May 02 2011, 12:59PM
Tim wrote ...
Hello,
- Needed current?
Best Regards,
Tim
The ball needs to be magnetic otherwise this won't work at all...
And you may want to try and use Barry's Coilgun simulator, since that's effectively what you're trying to build, just with a ball for a projectile.
Ash Small
Mon May 02 2011, 01:48PM
You could do it by firing a solenoid core into a ball. (energy transfer, elastic collision)
Tim
Mon May 02 2011, 06:27PM
Thanks for the quick respons.
I'm getting stuck in finding the right formula's to determine the wanted parameters.
Tim
