  • Guests: 57
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Mystery Particles From The Sun
jpsmith123
Sat Apr 30 2011, 02:57PM Print
Apologies if this has been posted here before, but I just saw this recently:
Adam Munich
Sat Apr 30 2011, 03:33PM
What is this I don't even
If the neutrino theroy is true, would it not be possible to change the decay of a radioisotope by placing it next to a very strong beta emitter? If so then we could make RTGs that have a low power mode and a high power mode!
ZakWolf
Sat Apr 30 2011, 05:39PM
I have study quantum physics a little but, it was only recreational, plus I am only 15. Its my understanding that a Neutrino, meaning "small neutral one" which is electrically neutral, and is able to pass through ordinary matter almost unaffected. So how can this particle affect the decay rate of a radio active sample ?
Sun May 01 2011, 01:22PM
Short answer, we don't know.
I would speculate that there might be a time during a given atomic decay when a nucleus is in a hyperdeformed state during which it can be affected by a neutrino hitting it.
This time may last attoseconds which explains why this effect is so hard to see despite the high neutrino flux.
As I said, this is speculation so take with a pinch of salt.
-A
jpsmith123
Sun May 01 2011, 02:07PM
As I see it, the other possibility is that solar activity is somehow affecting time itself.
Adam Munich
Sun May 01 2011, 02:12PM
jpsmith123 wrote ...
It's called gravity!
Hmm... could it be gravitational waves that are causing this?
jpsmith123
Sun May 01 2011, 02:26PM
If a gravitational wave is defined as a fluctuation in the curvature of space-time which propagates as a wave, then yes, the sun may be radiating gravitational waves as its core is rotating, or whatever its doing.
Ash Small
Mon May 02 2011, 09:34AM
I read somewhere that neutrinos, when in free space, are massless, but aquire mass when they pass through other matter. I understand it affects their velocity as well.
This would suggest that they do in fact, interact with matter.
(I'll try to find some links later)
EDIT: One article I read said something like 'the neytron is 'absorbed' by the nucleus, then 'ejected'. The phenomena was also correlated with the refraction of photons when traversing from one medium to another.
EDIT: Wikipedea says this:
"Neutrinos can interact with a heavier nucleus, changing it to another nucleus
This process is used in radiochemical neutrino detectors. In this case, the energy levels and spin states within the target nucleus have to be taken into account to estimate the probability for an interaction. In general the interaction probability increases with the number of neutrons and protons within a nucleus."
Bjørn
Mon May 02 2011, 11:44AM
This Link2 (.PDF) and this Link2 suggests that the effect is not real. The same does the fact that this information seems to come from a few people that is repeatedly promoting the same story without doing any new experiments.
jpsmith123
Mon May 02 2011, 01:07PM
