  • Guests: 38
Neon sign transformer care
kimbomba
Fri Apr 29 2011, 03:53AM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Hi everybody i am new to the forum and also new to HV, but i have already built a coil gun, a single transistor flyback driver and a boost converter cap charger. Today i bought my first NST, an Allanson 15 KV 30 ma unit. Sorry if the question has been answered but I searched the forum with no success. What are the general recommendations for taking care of a NST. Particularly I would like to know if I can run the transformer with a variac; i have seen videos where this is done but, ¿it is safe for long time periods? Thanks in advance
ScotchTapeLord
Fri Apr 29 2011, 04:11AM
If you are using the variac to lower the voltage then that will stress the transformer less than regular operation.
If you are using the variac to raise the voltage beyond line level then that could cause harm.
It seems that model of transformer may have ground fault protection. That will prevent arc-drawing.
James
Fri Apr 29 2011, 05:22AM
Generally speaking, there should be plenty of overhead to safely run the input at 140V, the max most variacs go to. As was already said, going lower than rated is no problem.
I've never actually worked with one of the ground fault protected transformers. Can't the protection be bypassed?
Xray
Fri Apr 29 2011, 01:56PM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
I've played with NST's over the years, and the best thing about them is the fact that they are intrinsically current-limited. What that means is, you can short-circuit the secondary winding, and it will never source more than it's rated current (30mA in your case). BUT (and this may be important) the NST may not be able to limit the secondary current if operated below its rated input voltage (I say "may" because I'm not certain). If operated at a lower voltage, the core may not saturate, which would allow the secondary to source current beyond its nominal value.
Comments?
Adam Munich
Fri Apr 29 2011, 02:16PM
An NST doesn't limit current via saturation, instead it has magnetic shunts between the windings to increase leakage inductance. I don't think any transformers are designed to be run at saturation.
Fri Apr 29 2011, 02:45PM
Grenadier wrote ...
Saturable transformers are used in some specialist applications, e.g.
Rev. Sci. Instrum. 63, 2138 (1992); doi:10.1063/1.1143180 (3 pages)
Magnetic pulse compressor using saturable transformer to excite excimer lasers
K. Kurihara, S. Kobayashi, I. Satoh, K. Shibata, M. Shigeta, K. Masugata, and K. Yatsui
To reduce the load on switching elements in the excitation circuit of excimer lasers, a new circuit has been developed to study the basic characteristics, where a saturable transformer is utilized in the magnetic pulse compressor. We have used a saturable transformer with a winding ratio of 1:4. The initial pulse of 8.5 kV, 2.0 kA, 3 μs was transferred to the output pulse of 34 kV, 8 kA, 109 ns, with an energy‐transfer efficiency of 58%. Using a saturable inductor as a charging inductor, furthermore, we have succeeded in reduction of the prepulse of the output voltage and enhancemet of the energy‐transfer efficiency
Xray
Fri Apr 29 2011, 03:33PM
Grenadier wrote ...
There are "saturable reactors", but you are correct about the NST not saturating. (my bad). It limits current by shunting some of the magnetic flux away from the secondary winding, causing (as you said) leakage inductance.
Adam Munich
Fri Apr 29 2011, 04:20PM
Where do you find all these random documents proud mary?
Fri Apr 29 2011, 05:44PM
Grenadier wrote ...
Not random is the answer.
Condense the arg into a few words or phrases which are only likely to occur together in a document containing information of the desired sort.
You must first define what you are looking for in order to find it.
James
Fri Apr 29 2011, 05:50PM
I recall the old Sola voltage regulating transformers used saturation to regulate the line voltage. They used to be common for computer equipment although you don't see them much anymore. I remember they ran hot and often were a bit noisy.
