  • Guests: 58
TSC International ( H for Oersted )
Tue May 03 2011, 04:56PM Print
I cant find a BH curve for some of TSC's ferrites. I really need to know the H value. Am I just not seeing it on there website? Surely any maker publishes this info, I mean every other maker Ive ever seen does. I only see a vague reference to the
"15 Oersted" graph.
In my other apps, my ferrites from other makers are spec'ed to 5 Oe, but above 3 Oe their function starts to go down. So the H (Oe's) are an important factor.
My material is the -50ALL type seen here in this PDF.
]50allgraphpage.pdf[/file]
Link2 I guess i could calculate it given the change in slope of u = B/H ?
instead of going through the H Oersted direction i think i can go at it this way:
At = B(Ae/Al)
Where:
At is ampere turns
B is in Teslas
Ae is area of center leg in meters
Al is intuctance in Henries
And then:
At/m = (N x I)/Mp
Where:
At/m is ampere turns per meter
N is number turns
I is current in amps
Mp is magnetic path in meters
Or...
H = (0.4 x Pi x N x I)/ Mp
Where:
H = Oerteds
Pi = 3.14
N = Number of turns
I = Current in Amps
Mp = Magnetic path in cm
Not sure if this derivation is right.
Antonio
Wed May 04 2011, 12:16AM
H is just (N x I)/ Mp ampere/meter, if H is constant.
To obtain it in oersteds, divide by 1000/(4 Pi), or 79.58.
Wed May 04 2011, 12:30AM
TY Antonio.
1304469003 2431 FT114770 Trmrgroup
Left: 800VA SMPS trfmr, Center: Planar cores, Right: 800VA trfmr stripped to ferrite.
