  • Guests: 34
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
anybody have a good plate current circuit
teravolt
Wed Apr 27 2011, 04:06AM Print
I am working on a 3 X 833a VTTC. this VTTC is Experimental. I want to switch it form cuttoff to saturate in a burst mode for sticatto. The circuit that I will use for a grid drive is a half bridge. I am hopping I can controle the efishency and output with the pulse width, dead time ect. to the the tube grids. The power supply that I built is about 3kv useing 4 mots. The three modes that I plan to start off with is half wave, full wave and filtered.does anybody have any good links? I am looking for advice on the things to monitor ie filliment voltage plate voltage plate current. I think I could use a toride ferite and resistor to pickup current to give me isolation from the plate and average it out by recifieing and filtering.When it is done I will feadback from the primary or secondary or tickler coil and eliminate the capacitor and resistor in the grid. It is still basicly a modified armstrong.
Wed Apr 27 2011, 04:47PM
teravolt wrote ...
If you'd like to post up a circuit diagram, we would have something to talk about.
teravolt
Thu Apr 28 2011, 03:40AM
ok hope this helps
1303962047 195 FT114245 Dual 833a Modified 2
Thu Apr 28 2011, 08:10AM
teravolt wrote ...
ok hope this helps
Can we see the capacitor and the resistor in the control grid circuit that you intend to eliminate?
teravolt
Thu Apr 28 2011, 01:41PM
I would like to use a current meter in the plate so I could tune it and check the average power. should I use a person probe and average it out or do you think a meter and bridge will work. I have also seen tube amp circuits that have the current meter in the cathode. du you have any recamendations Proud Mary
Thu Apr 28 2011, 03:42PM
teravolt wrote ...
Well, I'd connect one side of those filaments to Earth. Nothing will work with them hanging in the air like that.
As you are using triodes, it's up to you whether you measure Ia or Ik. I'd use a moving coil panel meter if it was my problem, but you must make sure you have plenty of de-coupling and by-passing if erratic operation is to be avoided.
But I'm not here to design your gizmo for you! smile There must be hundreds of books on valve oscillator design, and it would repay you to study them.
