  • Guests: 36
Ionovac Speaker
Chip Fixes
Wed Apr 27 2011, 09:26PM Print
For those of you interested:
magnet18
Wed Apr 27 2011, 10:36PM
SCEMATIC!!!
Happy dance doo do doo do; Happy dance doo do doo do cheesey
One question, does anyone know whats going on at c5,c6,c7, and c8 on the schematic? (Link2
Xray
Thu Apr 28 2011, 02:37AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
magnet18 wrote ...
SCEMATIC!!!
Those are "feed through" caps. They decouple any RF from feeding back into the power supply.
magnet18
Thu Apr 28 2011, 02:59AM
Xray wrote ...
magnet18 wrote ...
SCEMATIC!!!
are their values really essential to the circuit, or could I jury rig something and have it still work?
I hate ordering things :P
Xray
Thu Apr 28 2011, 03:14AM
magnet18 wrote ...
No, not critical at all. They are probably .001uf but anything from .001 to .01 would probably work just fine. They are feed through caps because the RF section is a separate assembly which is connected to the power supply via a multi-conductor cable. You won't need feed through caps if you mount all the components on one chassis. Just make sure that you use good layout and grounding techniques. If you have no idea what I'm talking about, then you have a lot of learning to do! wink
magnet18
Thu Apr 28 2011, 03:32AM
Xray wrote ...
magnet18 wrote ...
Crystal Clear cheesey
I figured they weren't that important, but I wanted to check. With something this simple noise prevention issues are usually unnecessary.
Chip Fixes
Thu Apr 28 2011, 03:41AM
Since this schem is so old i take it some of the parts can be replaced with more "modern" parts, correct?
magnet18
Thu Apr 28 2011, 03:56AM
the only thing on there thats really outdated is the pentode, if you felt adventurous you could replace it, but it's probably easiest to just use one.
as for everything else, just make sure that the values are the same and the voltage ratings are high enough.
the SI units have changed some, google for sites on replacing the capacitors in old radios and they should explain it. I had a good one once but i can't seem to find it...
just google replacing antique radio caps, the units is all you're worried about anyway..,
Chip Fixes
Thu Apr 28 2011, 03:24PM
yep that's what i figured, I might look into recreating one of these this summer...
magnet18
Thu Apr 28 2011, 08:09PM
Camp Badger wrote ...
summer? I was thinking like two weeks from now..
