  • Guests: 49
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Variable Speed for Drill Press
Chip Fixes
Mon Apr 25 2011, 08:57PM Print
I have an old drill press but it only has one speed. I was wondering if I can replace the light switch with a light dimmer to make a it a drill press with a variable speed adjuster?
1303765072 3781 FT0 Drill Press
Mon Apr 25 2011, 09:20PM
Camp Badger wrote ...
OMG that drill press is absolutely squee.
Get a small Variable Frequency Drive for it, and scrape off the paint on the machined part of the column, so you can slide the table up and down....Finish it with 120grit emery cloth.
Cheers, Finn Hammer
Mon Apr 25 2011, 09:35PM
Squee, indeed.
A regular lamp dimmer would probably explode. There is a device called a ceiling fan speed controller that might be more promising.
But the best (and most expensive) solution is replace the motor with a 3-phase one and use a variable frequency drive. Just controlling the voltage doesn't work that well with an induction motor.
Mon Apr 25 2011, 09:41PM
The usual method of changing the drilling speed on pillar drills of this vintage is by altering the diameter of the drive pulleys, which are often stacked one above the other on the spindle.
Ash Small
Mon Apr 25 2011, 10:06PM
I'd second PM here.
If you can't machine some, maybe look on Ebay.
James
Mon Apr 25 2011, 10:18PM
It depends on the type of motor, if it has a separate start winding then you can't easily control the speed. You can usually hear the click of the starting switch closing again as the motor coasts down after you switch it off.
I got a cute little VFD and a 1/3HP 3 phase motor I intend to mount on my little drill press to get rid of the annoying stepped pulley system. A vintage machine like that I would be tempted to just leave it as is, unless you can find a vintage 3 phase motor.
Chip Fixes
Mon Apr 25 2011, 10:22PM
Alright, I will look around, otherwise i'll just leave it as is, I believe everything's original except the power cord which I replaced yesterday :) It runs well though
EDIT: i'm looking to sell it if someone wants to make an offer haha
Tue Apr 26 2011, 02:26AM
My drill press is just like PM described. If you want me to send a picture of the variable pulley discs let me know.
Renesis
Tue Apr 26 2011, 01:28PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
The real gold strike would be if you found a scrapped threadmill, they have all the parts you need for such a project. Their motors are somewhat powerful too.
Chip Fixes
Tue Apr 26 2011, 03:02PM
Renesis wrote ...
ah if you meant treadmill, then yes, i have some parts, including the motor. Although i am not sure the motor works as well as it should, it seemed to not be going as fast as it should when I took it apart, like it's worn out.
