  • Guests: 147
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
What is this?
Chip Fixes
Sun Apr 24 2011, 09:06PM Print
Obviously it's a transformer but what kind and what can I use it for? It was hooked up to a treadmill motor that takes an input of 100vdc.
The label says:
719C2
EIA-17-9325
327 B3 MEXICO
1303679153 3781 FT0 Transformer
magnet18
Sun Apr 24 2011, 09:11PM
It's either step up for high voltage, or step down for high current, I would guess the latter, but it could be reversed.
If you have a low voltage AC source apply a couple volts to one side and see what happens on the other side.
Experimentonomen
Sun Apr 24 2011, 09:12PM
Looks like it only has 2 wires, then its a ballast(current limiter) or a filtering choke.
Chip Fixes
Sun Apr 24 2011, 09:25PM
Yes, only two wires. Looks like it will be going back into my box-o-parts
James
Mon Apr 25 2011, 04:27AM
There's one just like that in my treadmill, as I recall it's a filter choke in series with the motor, a large permanent magnet DC thing.
Chip Fixes
Mon Apr 25 2011, 03:23PM
Alright, I might do a teardown on it later this week if I have time
doctor electrons
Mon Apr 25 2011, 10:59PM
Aka, line reactor. It keeps noise from the motor from getting back into the line. Usually you see them in front
of three phase setups, like a variable frequency drive running a large motor. I wouldnt toss it out!
magnet18
Tue Apr 26 2011, 12:05AM
Right then, I've been corrected, figured the other wires were hidden.
Anyway, hold on to it, ballasts are useful, especially if you get into more powerful things like x-ray transformers (and heck, even MOTs)
Chip Fixes
Tue Apr 26 2011, 01:52AM
Alright back into the bin-o-parts it goes then!
