  • Guests: 32
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
photo transistor
radioman
Sat Apr 23 2011, 11:07PM Print
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
I have a clear photo-transistor from a Ramsey laser trip sensor kit. The transistor has a green dot on the bottom and the corresponding lead is the shorter of the two leads. Do I assume correctly that the lead marked with the green dot is the negative or cathode? Is the longer lead usually positive?
Thanks,
Radioman
Inducktion
Sun Apr 24 2011, 12:10AM
the shorter lead is negative, longer is positive, this goes for all of the LED type packages.
radioman
Sun Apr 24 2011, 02:09PM
Thank you, Inducktion! My Ramsey assembly manual made a mistake by calling the negative lead the "long one".
Radioman
