  • Guests: 44
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
EFA Loudspeaker
Chip Fixes
Fri Apr 22 2011, 01:35AM Print
Thought I would share this with anyone who is interested Link2
Any thoughts?
magnet18
Fri Apr 22 2011, 02:03AM
I saw this one on that site that x-ray linked to, I think it should work well, but it might be less practical without some sort of ozone control... corona wind puts off a lot more of the stuff.
Chip Fixes
Fri Apr 22 2011, 02:30AM
that's true, I would still love to build it though :D where are the arc[s] though? As far as I can tell from the picture, there are not any gaps in the metal rods.
magnet18
Fri Apr 22 2011, 03:00AM
No arcs, it operates by audio-modulating the corona discharge.
I personally kinda want to build a flame speaker, efficient or not...
Chip Fixes
Fri Apr 22 2011, 03:19AM
yeah, it's no fun if you can't see it :P
magnet18
Fri Apr 22 2011, 03:26AM
You can see it, it's a purplish haze... try powering up your flyback with the leads really far apart, you should see it. (provided it doesn't arc on the bottom first)
Chip Fixes
Fri Apr 22 2011, 03:52AM
ha yeah, got it. And I solved the arcing pins problem a while ago. Just put some insulation around the pin and hot glue it down, problem solved!
magnet18
Fri Apr 22 2011, 03:56AM
I actually had one emit corona inside a little air bubble in the hot glue once, purple glowing hot glue... fun till it catches on fire... smells bad cheesey
Chip Fixes
Fri Apr 22 2011, 04:04AM
haha wow that's sweet! i arced through a water bottle once, actually the electricity went around the water bottle so it was like arcing to the bottle
magnet18
Fri Apr 22 2011, 09:56PM
If you're ever questioning how hot plasma is, stick a sock in it... my dad decided to try that one morning, burst into flames before it even touched the arc.
