  • Guests: 49
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Geigercounter problem
hv-friekie
Thu Apr 21 2011, 12:18PM Print
hv-friekie Registered Member #2273 Joined: Thu Aug 06 2009, 07:02PM
Hey guys,
I am building a geigercounter at the moment, it's based on the second schematic on this site:
Here is my Version on eagle:
The problem is that the boost-converter part just doesn't do anything. It doesn't draw any current and i get no Voltage at the output.
Has any one an idea where the problem could be?
By the way: I replaced the 2n4403 with a mpsa56 and the mpsa18 by a bc550b.
Best regards,
Philipp
Thu Apr 21 2011, 02:57PM
That might be the problem, have you checked the gain on the BC550B?
Often with these oscillator circuits subbing parts will result in a non working circuit or one which draws excess current.
Also, the transistor on the coil itself is rated for much higher voltages than a "jellybean" transistor.
Your substitution has a Vmax Vceo of 45V so at best you will get a fraction of the desired voltage.
-A
hv-friekie
Thu Apr 21 2011, 04:00PM
Thank you for your answer.
I replaced the transistors because they were not available in the shop i ordered the rest.
So i guess i have to buy the original transistors from other online shops.
I will inform you wether it works or not when i got the new transistors.
Best regards,
Philipp
Adam Munich
Thu Apr 21 2011, 11:15PM
Here's an idea that will save you a lot of headache. Do you happen to have any CCFL inverters on hand? If you connect a voltage doubler to them and power them via an adjustable supply such as the lm317 you can get a variable voltage power source, excellent for a geiger tube. This one only draws 13mA so it runs off of a 9V battery just fine. Link2
Fri Apr 22 2011, 05:26AM
Hey Grenadier.
Thats a very neat trick, thanks for sharing it!
-A
#include "I_HATE_Norwalk_Virus.h"
hv-friekie
Sun May 01 2011, 03:12PM
I fixxed the problem, the reason was a wrong pinout in eagle of one transistor, so it at least wasn't my fault xD
Here are some pictures:
And a video:
Kind regards,
Philipp
tarakan2
Sun May 01 2011, 04:39PM
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
What voltage does it take to bring the tube to operational state?
Is it 400V?
Similar to a strobe light?
hv-friekie
Sun May 01 2011, 04:58PM
The zenerdiodes are 120V, so the ouput voltage of the boostconverter is 240V which gets doubled, so i have about 500V on the tube.
tarakan2
Sun May 01 2011, 05:20PM
I see.
Zener diodes set a precise output voltage so the tube doesn't spark over?
hv-friekie
Sun May 01 2011, 06:34PM
yep, exactly.
