  • Guests: 53
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Isolators
ScotchTapeLord
Mon Apr 11 2011, 03:20AM Print
So, I was researching means of achieving galvanic isolation. Of course, there's the GDT and the optocoupler, and then there are those slow bootstrap high side drivers which tend to have 600V of isolation.
Today I ran into a new family that has breakneck speeds. At first I was turned off by the name "Digital Isolator" but then found in the datasheet that they are good down to DC.
<10ns propagation (worst case scenario)
up to 5kV galvanic isolation
-and under $2 for a single version!
I've integrated them into my DRSSTC design and will let you know how they work out... eventually!
Just wanted to know if everyone but me already knew about these or if they are a serious alternative to our current methods.
Mon Apr 11 2011, 03:43AM
ScotchTapeLord wrote ...
Nice parts, especially when you need to transfer a number of digital signals across an isolation barrier.
How are you providing power to the secondary side of the isolators?
ScotchTapeLord
Mon Apr 11 2011, 04:06AM
Klugesmith wrote ...
Separate DC supply.
Adam Munich
Mon Apr 11 2011, 05:13AM
"output current drive channel = 10mA"
So it can't be directly used to drive mosfets, but a nice part nonetheless.
ScotchTapeLord
Mon Apr 11 2011, 05:55AM
There is a sibling series of isolators that have gate drive capability: Link2
but I chose this particular one because I was planning on using it with high side drivers similar to this: Link2
Using separate isolators and gate drive chips, I can get the propagation delays below 20ns into the gate driving FET bridge, but it would require 4 separate components.
Using the gate-drive enabled chips I would only reduce the component count by two but would subject myself to up to 60ns of latency.
On the other hand, it gives an easy way to control dead time...
But I'd have to invert the signal going into the driver because the gate-drive rated ones are only non-inverting.
Gosh.
