  • Guests: 59
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Wiring a transformer?
Marcus Quintilian
Mon Apr 11 2011, 02:18AM Print
Marcus Quintilian Registered Member #3761 Joined: Tue Mar 15 2011, 12:29AM
I have a 115v 100VA/ 28v out transformer and it has 3 wires for the primary red, white and brown. I wired the primary's red and brown wire to the hot wires and the white wire to earth ground. when i plugged it in I blew a fuse, I'm thinking that I have a short but I'm not really sure. Any help would be great!
James
Mon Apr 11 2011, 03:52AM
Are you SURE the three wires are the primary? That sounds a lot like a center tapped secondary.
Use a multimeter to measure the resistance between the wires. The two wires with the highest resistance between them will be the 120V primary.
Mon Apr 11 2011, 05:04AM
I take it there's no documentation.
As James says, start with an ohmeter and determine which sets of wires are isolated from each other, and which set has generally higher resistance.
I can't think of any reason a winding with three wires (e.g. a tap at some intermediate number of turns) would ever want two of them to be shorted together. What were you thinking? In the worst case, the white wire is a center tap; by applying voltage between it and the red & brown together, the winding inductance cancels out and you have just the two DC resistances in parallel. (a few ohms?).
In a more common case, the red and brown wires are electrically close together -- let's say if red is 120V from the white wire, then brown will be 100V from white and 20V from red. By applying 120V to -both- you induce 24V between brown and red, which are shorted together!
radiotech
Mon Apr 11 2011, 06:52AM
Try wiring up a lighbulb, 120 Volt 100 Watt in series with the
power cord you plug into the wall socket. Then power up the
transformer, through the light bulb with a 8 0hm 100 watt
resistor on the secondary.
When the wiring is correct on the primary, the lightbulb will
glow about 3/4 brightness and there should be about 12
volts across the resistor on the secondary.
