  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
tl494
wpk5008
Fri Apr 08 2011, 02:41AM Print
wpk5008 Registered Member #3546 Joined: Tue Dec 28 2010, 08:24AM
Does anybody know of some good resources to learn about the tl494 and other pulse width modulating circuits? I had asked one of my professors if he could show me what he knows about them, but he mostly just blew me off and told me to mess with them until I get what I want, but I haven't been having much luck with it. I've read both the data sheets and the application notes already too. Honestly, I am a little worried all the tl494's I bought might be damaged because I can't seem to get the saw-tooth waveform from pin 6 to show up on my scope when I build the test circuit in the data sheet.
Fri Apr 08 2011, 08:25AM
I remember asking the lecturer on my Power Electronics course a similar question. At least he was honest, and admitted that he didn't know anything about the TL494.
The TI datasheet is terrible, try to find one of the other manufacturers' datasheets, like OnSemi.
The test circuit doesn't necessarily do what you think. It is just a description of the test jig used in the maker's lab that was used to measure the specifications on the datasheet, not an actual application circuit.
I assume you have a proper X10 probe on your scope, not a length of coax with alligator clips on the end.
hboy007
Fri Apr 08 2011, 09:20AM
May I suggest the application note related to TL494 design?
James
Fri Apr 08 2011, 06:19PM
These should get you started.
In my experience, the chips are pretty tough. Also good is that they're dirt cheap and easy to find since the majority of AT and ATX computer PSUs used them or equivalents.
Just connecting power and a timing capacitor and resistor ought to get the oscillator running and give you a sawtooth.
