  • Guests: 51
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
neon lamp as GM tube
Microwatt
Thu Apr 07 2011, 06:35PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
would it be possible to run a neon lamp as a geiger tube. lets say we bias the lamp to 40vdc just under the threshold for discharge. would it pick up radiation?
Thu Apr 07 2011, 06:37PM
A friend of mine was experimenting with this, result - the neon lamp was extremely insensitive.
James
Thu Apr 07 2011, 06:40PM
The other problem is that they lack a quench gas, so once ionized by radiation they tend to continue to conduct. You can get some really cheap Russian geiger tubes on ebay, the worst of them will work better than a neon lamp.
Thu Apr 07 2011, 07:13PM
The glass is quite thick,
probably one reason?
(I don't know absorbtion rates)
If quenching is the only problem use a tiny capacitance in parallel charged by a tiny current.
I think that neons can 'flash' 100's of Hz,
by that time I'd have legged-it (ran far far away!)
Shrad
Thu Apr 07 2011, 07:17PM
if you could place the lamp under the right pressure with a small recipient of quenching agent like alcohol or ether for several hours, and slowly (for a couple days) reduce the pressure to atmosphere, you could allow molecules to pass through and add to neon, maybe acting as a quenching agent
this is purely theoretical and an idea of mine...
if you heat the lamp to higher temperature (two to three times ambient) its porosity will raise accordingly
I have a helium-cadmium laser which refills its helium by heating a quartz reservoir, at high pressure
Thu Apr 07 2011, 07:56PM
Quenching is not the issue here, since it is not uncommon for GM tubes to use external electronic quenching to achieve high count rates without pulse pile-up.
The question is whether a given neon bulb has a GM region in which Townsend avalanches can occur - a question most easily determined empirically, I'd say, but I wouldn't be optimistic.
Chris Russell
Thu Apr 07 2011, 11:11PM
Chris Russell ... not Russel!
If I remember correctly, neon bulb electrodes are coated with thorium, to make the lamp easier to ignite. That makes them pretty useless for GM service, but interestingly does make them useful as an extremely high value resistor.
Nicko
Fri Apr 08 2011, 05:07AM
I know very little about GM tubes, but a bit about cold cathode discharge tubes (like neon lamps, nixies etc.)
What might be better to use (more sensitive) is a trigger tube like the Z700U or similar - these have bare electrodes with a fairly high work function, but also can be used with their trigger electrode used as a source of ions for the main anode/cathode gap - the problem with general trigger tubes if that they required some external source of radiation to make their triggering deterministic/reliable - with coated electrodes which have a lower work function, daylight was ok, but uncoated required UV at a minimum but allowed higher current.
The trigger electrode circumvents this problem by allowing the creation of enough free ions that the main gap behaviour becomes predictable and much more sensitive even with uncoated electrodes.
Point to make is that the trigger electrode is often coated so the trigger current must be carefully controlled if a negative (quenching) pulse is used in order to prevent the coating sputtering onto the anode and changing the characteristics of the whole tube.
Microwatt
Fri Apr 08 2011, 07:21AM
if you put voltage on the electrodes you decrease the work function and make the lamp very sensitive
Fri Apr 08 2011, 09:36AM
Charlie Wenzel has a whole shtick about neon bulb detectors here:
