  • Guests: 50
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Fill-gas in glass window PIN photodiodes
Thu Apr 07 2011, 02:06PM Print
Does anybody please have certain knowledge as to the nature of the fill-gas in glass window PIN photodiodes like BPX65?
Shrad
Thu Apr 07 2011, 03:27PM
should be argon, maybe xenon or nitrogen... basically any inert gas
what you can do is expose it to light at certain wavelengths (common laser diodes, with attenuation) and compare with absorption spectrum of those inert gases to see where absorption takes place
I think it might be a mix though, maybe with a quenching agent to avoid avalanche if those are used in sensible equipments
Thu Apr 07 2011, 04:16PM
Thank you for your suggestions, Shrad.
I have sent my query to Centronics, and hopefully will hear from them soon.
plazmatron
Mon May 09 2011, 06:34PM
There is a bit of info on this here:
Les
Mon May 09 2011, 07:33PM
plazmatron wrote ...
Thanks. smile
