  • Guests: 80
Inducktion (32)
Standa (31)
nabzim (33)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
What do you think of this multi-purpose driver ?
Wed Apr 06 2011, 04:04PM Print
Hey all,
While searching for a good ignition coil driver, I found this one from RMCybernetics:
Ocxi10
IGBT is an IRGB4061DPBF
Features and Specifications
• Wide supply voltage range (12V – 30V)
• Switching voltage range from 0V to 400V
• Max output current 9A * continuous, 36A peak
• Frequency range 0.01 Hz to 1.5 MHz **
• Pulse width adjustable between 0% and 100%
• Compact design
• High quality double layer PTH, 2oz Copper PCB
They sell it for £43, which sounds fair price
I thought I could even use it as a signal generator (with all needed protections) to drive my own home made power stages and ensure I won’t damage the unit itself...
What do you think of it ?
Thanks for your advices as usual smile
