  • Guests: 92
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
How dangerous is it to view a flyback arc directly without glasses?
Inducktion
Tue Mar 29 2011, 03:39AM Print
Just curious, because apparently I have a light sensitivity issue, and bright stuff gives me horrible migraines.
I'm talking arc's from a ZVS driver, and also, arcs from voltage multipliers and marx gens.
Thanks!
(I can get sunglasses if needed, believe me I don't want migraines.)
dmg
Tue Mar 29 2011, 03:41AM
If it gives you migranes, I suggest you get some good sunglasses that can block UV, or #4-#5 welding goggles (still fairly visable looking through them, as they are designed for oxy-acetalyne welding, so you can see what you are doing, but it will block out the light to quite tollerable levels).
I personally never had an issue with arc brightness except when I tried making a carbon arc lamp (a crude setup with some carbon rods, a shiny salad bowl and an arc welder).. that was ungodly bright. (needed a #10 arc welding mask just to view the "heart" of the lamp).
Xray
Tue Mar 29 2011, 04:41AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
A portion of the light given off by electric arcs is in the UV range, which your eyes cannot adjust to. So, even if the light doesn't cause pain in your eyes, it's not an indication that no damage is being done. Whether or not your eyes seem to be sensitive to bright light, it's never a good idea to stare at electric arcs, even if the overall brightness appears to be dim.
Adam Munich
Tue Mar 29 2011, 06:03PM
I've never had problems with flyback arcs, and they are quite "dim" as a matter of fact. You can veiw the UV output with a piece of bleached paper, and a FBT arc doesn't make it shine too bright at all.
MOTs on the other hand have ungodly bright arcs, and you'll need 2 pairs of sunglasses if you want to play with one.
Maybe it's not the light that is giving you a headache, but the intense ultrasound instead?
Inducktion
Tue Mar 29 2011, 06:36PM
Grenadier wrote ...
That wouldn't be the case, because I had the same issues with a cutting torch. Cutting torch = hot metal = bright stuff = pain for meh.
It's gotta be the brightness.
Ash Small
Tue Mar 29 2011, 06:50PM
Polycarbonate safety glasses block UV light, and they are completely transparent. There is a condition known as 'arc-eye' which can be caused by being in the vicinity of welders, but polycarbonate safety glasses prevent this. symptoms are headaches, nausea, etc.
EDIT: Apparently repeated exposure to UV can cause permanent damage.
LIGHT
Tue Mar 29 2011, 07:51PM
LIGHT Banned on 4/6/2011 for unsafe, irresponsible behavior.
Registered Member #3442 Joined: Fri Nov 26 2010, 04:09AM
Maybe you could use some polycarbonate UV blocking laser shades, and sungalsses, so all UV is diminished.
James
Tue Mar 29 2011, 08:38PM
A cutting torch heats metal to incandescence which produces some UV. Not nearly as much as an arc welder, but enough to cause problems. Yes, UV is damaging, it kills biological matter, it's why UV lamps can be used for sterilization. X-rays are nothing but *really* deep UV photons.
haxor5354
Tue Mar 29 2011, 09:13PM
whats bright? the electrodes or the arc it self?
Shrad
Wed Mar 30 2011, 08:32AM
both of them
look at these discharge spectrums :
principaly oxygen and nitrogen, and also iron, carbon and aluminium
