  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
What's the best way to strip 30 gauge magnet wire?
jpsmith123
Wed Apr 06 2011, 12:01AM Print
I'm not sure exactly what kind of wire it is, but I think it's Essex "amber", with a "modified polyester base coat" and a "modified amide/imide overcoat". Some magnet wire can be soldered without stripping the insulation off, but not this stuff, apparently.
big5824
Wed Apr 06 2011, 12:02AM
just scrape it off with a knife
Mattski
Wed Apr 06 2011, 01:07AM
I use a small piece of sandpaper, wrap it around the end of the wire, and drag it towards the end. Repeat as necessary.
2Spoons
Wed Apr 06 2011, 01:25AM
polyimide can be dissolved with sodium hydroxide dissolved in alcohol.
Doubl3 Helix
Wed Apr 06 2011, 03:23AM
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
No idea if this would be recommended or not, but sometimes I just use a flame from a lighter to burn off the coating real quick.
HazzWold 1993
Wed Apr 06 2011, 03:52AM
I usually just burn it, then sandpaper it to shine
Turkey9
Wed Apr 06 2011, 03:59AM
I use a small file. Pain in the but that magnet wire is. Handy though
dmg
Wed Apr 06 2011, 04:44AM
I second hazzwold, burn it off, I use a lighter and a razor blade to rid of the residue.
jpsmith123
Wed Apr 06 2011, 02:43PM
Thanks for all the good ideas!
I'm going to experiment on a sample of the wire right now.
radiotech
Wed Apr 06 2011, 06:55PM
A method used by radio repair shops is to put a blob of solder
on an iron tip while dragging the end of of the wire through.
Its important to do this in one quick action before flux in
the solder boils off. This leaves a tinned end.
The other way is to wrap the insulated wire around a tinned
coil terminal and apply iron and solder quickly.
In the best of worlds you would have a Bunsen flame at hand
with your choice of flame color parts to pass the wire quickly through
to get bare metal.
