  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Question About LTSpice
jpsmith123
Tue Apr 05 2011, 03:51AM Print
I don't know much about LTSpice, but apparently there are some here who are familiar with it, so maybe someone knows:
Does it have a spark gap model built-in or is there a spark gap macro or something available for it anywhere?
3l3ctrici7y
Tue Apr 05 2011, 07:02AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
When selecting a component; in the Misc directory, there is a component called neonbulb. After you place it, right click on it and you can adjust various parameters. The ones I see are Vstrike, Vhold, Zon, Ihold, and Tau. By adjusting those values, you could possibly make it into a passable spark gap for whatever you're doing.
I have never known LTSpice to get picky about currents in things... so I wouldn't imagine it'll would give you any grief about running 5000 amps through that "neon" bulb ;)
jpsmith123
Tue Apr 05 2011, 11:55AM
Thanks for the info.
Do you know what the "Tau" parameter is?
Tue Apr 05 2011, 12:08PM
I'd guess it's the time constant of ion recombination or whatever.
Mattski
Tue Apr 05 2011, 05:44PM
If you go through the LTSpice directories you can find the model that they use:
wrote ...
* Copyright © Linear Technology Corp. 1998, 1999, 2000, 2001, 2002, 2003. All rights reserved.
.subckt neonbulb 1 2
S1 1 2 2 N001 G
S2 2 1 N001 2 G
R1 1 N001 100Meg
C1 N001 2 {Tau/100Meg}
.model G SW(Ron={Zon} Roff=1T Vt={.5*(Vstrike+Vhold)} Vh={.5*(Vstrike-Vhold)} Vser={Vhold-Ihold*Zon})
.param Vstrike=100 Vhold=50 Zon=2K Ihold=200u Tau=100u
.ends neonbulb
So the tau as modeled is an RC turn-on/turn-off time constant, probably describing ion recombination as Steve said. And if I'm reading it correctly there appears to be a fixed 100MEG in series with Zon, which seems strange, but I don't usually parse netlists in my head so give a read through for yourself as well.
