  • Guests: 45
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
X-ray crystallography
Linas
Mon Apr 04 2011, 11:52AM Print
Hi, does any one try and succeeded by making crystal diffraction picture on intensifying screen ?
I want to try do it like this:
take salt crystal, drill 0,8-1mm hole in lead sheet 2-3mm thick, and place intensifying screen 5-10cm away from lead sheet, and with good camera (1000iso, 2,8, 30s or even more for exposure) take picture, and hopeful get some nice pattern of crystal :)
i have quite concentrated 80-120KV x ray source ( well, not yet, but soon)
Will it work ?? neutral
0228 Zl
Mon Apr 04 2011, 12:58PM
Hi Linas,
if you want to do Laue patterns, don't waste your money on some dreadful old medical relic, when what you need is a tube with an integral collimator, like these
Svetlana BS5-W and BS5-Cu of mine:
Ray Tube Bs5 Cu And W
Which I mount like this:
1292677563 543 FT0 Xray Tube On Mounting Base Plate Assembly 014
I would also suggest you fix your Gd2O2S:Tb screen to the front of an image intensifier, to avoid very long exposure periods.
Linas
Fri Jul 08 2011, 02:01PM
that wasin't that hard, all i did i take around 6cm steel wall, drill hole 2mm in diameter, used some nice mononcrystall from mosfet, and 2 min exposition with intensifying screen, and after developing film i get this smile
1310121323 1143 FT116086 P1590713
not bad, huh?
hboy007
Fri Jul 08 2011, 11:07PM
looks good, now name the miller indices wink
