  • Guests: 67
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
The Fryback Transformer
1 2 3 4
Adam Munich
Mon Apr 04 2011, 05:01AM Print
Ladies and gentlemen of the forum, I present to you a marvellous device that will revitalize your health and bring wondrous wealth and prosperity to your families and all future generations. Straight from Nikolai Tesla's labs I bring you a fantastic revelation in high voltage transformer technology, made with nothing but the latest and greatest materials this marvellous transformer will supply all the milliamperes you'll ever need along with more than four thousand volts! Such mind boggling wonders can be had with this magnificent transformer...
/1920's sales pitch
So my Fryback is done. After 24 man hours of work, 40 layers of windings and at least 1/6th of a mile of 28ga wire it is ready for action.
How I made it:
Step 1; Link2 wind wire.
Step 2; Link2 coat with 5 layers teflon tape
Step 3; Link2 One layer of e-tape and moar wire. Then put e-tape strips around edges.
Step 4; Link2 Repeat until brain melts
Step 5; Link2 Attach silicone insulated wire
Step 6; Link2 Cover it with 7 coats of liquid electrical tape
And here it is next to a 555 timer. Link2
When fed with 36V by a zvs it puts out 4kV at [YTB] milliamperes. Since I used 40 layers that's a max of 200V between layers, and seeing as I used at least 3kV worth of teflon and tape this transformer could probably be fed 56V and still work just fine. Primary is 4+4 of 12ga litz.
The core gets a little warm but the metal clamp gets smoking hot. I need to make a plastic one for it as it is robbing much of my energy. W/O the clamp arcs are one inch thick, w/ the clamp they are only .7in thick and shorter. Nonetheless they are ridiculously hot and I still need to measure the current. The secondary stays cool even with 3 minutes of continuous arcing.
And a video in which I couldn't get the arcs to stay put. Damn wind. Link2
Mon Apr 04 2011, 05:10AM
Nice chicken stick! (with chicken)
Some of those pics seem to be doubled up when I click on them.
Adam Munich
Mon Apr 04 2011, 05:29AM
Fix'd
magnet18
Mon Apr 04 2011, 05:45AM
Those are some nice arcs, very nice.
Out of curiosity, what circuit are you using to drive it?
Freitsu
Mon Apr 04 2011, 09:34AM
Freitsu Registered Member #3147 Joined: Sun Aug 29 2010, 10:53AM
A little bird told me it was powered with a ZVS circuit...
PS.
Nice work Grenadier! :D
Mon Apr 04 2011, 05:38PM
Yeah pics are better now, what freq are you running at that you felt compelled to use litz?
Xray
Mon Apr 04 2011, 07:33PM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Nice job! You should start a business making FRYBACK transformers (if your brain can handle the stress! LOL).
radhoo
Tue Apr 05 2011, 08:27AM
Nice work, but it has a major problem: all that tape will slowly slip off the center, and first you'll get something like a cone, than it will fell off completely. Since tape's adhesive doesn't harden after being applied, it is free to move in any direction, and because of the shape you've created the tendency is to get off the roll, and fill the middle.
It's fixable - but you need to act before the tape shape starts distorting: simply put it between two plastic discs, and fix those together using a few screws.
-or- try the design with epoxy that I posted a few days ago (but probably you've seen it already): Link2
Adam Munich
Tue Apr 05 2011, 10:52AM
@Patrick
I used litz because it's flexible
@Xray
I'm not making another one of these for at least a year.
@Radhoo
I don't think it'll be a major problem with the liquid tape on there holding it in place. So far I haven't seen any sign of slippage.
The biggest problem is the iron stealing my power. The other day I pumped 540 watts into the FBT and the arcs only looked like 300W ones at best. I need a plastic clamp or something...
Dr. ISOTOP
Tue Apr 05 2011, 04:51PM
I use a wood clamp on my big ferrite transformer, and it works pretty well.
