  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Solder Stencil material and thickness
rp181
Fri Apr 01 2011, 01:22AM Print
I need a a solder stencil for a upcoming PCB, and was wondering what material and thickness to use. The smallest pads are on a 127 QFN package, and are .3mm square. Because this is so small, I was thinking 2 mil (.002") thick. What material? I am thinking type 302 stainless steel.
Any thoughts? The stencil will be machined using FIB (Focused Ion Beam).
Turkey9
Fri Apr 01 2011, 04:32AM
Stainless steel would be the material of choice if you are going to be populating thousands of boards. Kapton is cheaper and works great as well as stands up to a hundred or so uses.
rp181
Sat Apr 02 2011, 02:43AM
Stainless is actually cheaper for me, only about $6. Not even sure if FIB is compatible with non-metals.
Ash Small
Sat Apr 02 2011, 06:20AM
Why 302 stainless and not the (usually) more common 304 or 316?
Is this just because you happen to have some that is the correct thickness, or for some other reason?
EDIT: From Wikipedia
"If the sample is non-conductive, a low energy electron flood gun can be used to provide charge neutralization. In this manner, by imaging with positive secondary ions using the positive primary ion beam, even highly insulating samples may be imaged and milled without a conducting surface coating, as would be required in a SEM."
rp181
Sat Apr 02 2011, 12:58PM
304 is also available, but I said 302 as it has a higher carbon content, and will be more rigid.
