  • Guests: 32
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
will these work for SOIC to DIP?
Inducktion
Wed Mar 30 2011, 01:51AM Print
They used SOP packages for the traces, but they look the same as SOIC.
]soic_to_dip.zip[/file]
1301449901 3637 FT0 Soic To Dip
Adam Munich
Wed Mar 30 2011, 04:39AM
Well that assembly looks wider than a DIP...
Electroholic
Wed Mar 30 2011, 09:47AM
On a dip8 the 4 corner pins form a square.
High quality adapters usually have to so8 mounted 90degrees to the dip8 footprint. this will provide enough area for proper pad dimensions. as will as clearance for soldering.
And if you want an so8 to dip8 carrier, you will need to find good quality turned pin headers and machined pin sockets.
Square pins are too big to go into standard sockets and will damage them.
James
Wed Mar 30 2011, 04:46PM
I made some SOIC to DIP adapters a few years back, I can find the layout if anyone needs them. It only takes a few minutes to whip up a sheet of them in KiCad.
Inducktion
Wed Mar 30 2011, 08:05PM
James wrote ...
I could use them....
James
Wed Mar 30 2011, 10:01PM
Inducktion wrote ...
James wrote ...
Is there a place to upload files? If you PM me with your email addy I'll send you some.
Inducktion
Wed Mar 30 2011, 11:29PM
James wrote ...
James wrote ...
You can just put them on a zip file and upload them here so everyone can use them, but if you want it to be private my email is **link**
great is misspelled on purpose. xD
dmg
Wed Mar 30 2011, 11:43PM
Well.. PCB's aside, a while ago Grenadier gave me an idea which I found working half decent:
more or less soldering jumpers from the DIP connectors to the pins of the SMD.
IIRC they make actual SMD > DIP adapters that are pressfit.. but I forgot what company does those. but for something quick and cheap.. this isn't too bad.
Dip
James
Thu Mar 31 2011, 06:06PM
I was just looking and realized the adapters I made are not DIP either, but just rows of pads I can solder wires to or stick in a breadboard. The problem is that the SOIC is too wide to fit between the DIP pads, you end up with several pins touching some of the DIP pins. I could make some that put SOIC on a wide (.600) DIP layout though. Grab a copy of KiCAD (free) and have a go with it, it's super easy to make custom adapters, I use it for all of my PCBs.
