  • Guests: 41
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Ferrite Core from Monitor
Inducktion
Sun Mar 27 2011, 10:05PM Print
Hey all, I got a ferrite core transformer (not the flyback) from a monitor. I managed to salvage the bobbin and the ferrites successfully, and was wondering, how do you usually tell how much power the core can handle?
It's a pretty sizeable transformer, and its got a logo and some numbers on the top.
I have a dollar bill behind it for size.
1301263505 3637 FT0 P1060307
1301263505 3637 FT0 P1060308
Sun Mar 27 2011, 10:15PM
Well that one could surely handle 500 watts continuous fine tongue . The ferrites in monitors and TVs usually handle from around 100-400 watts in normal use.
Experimentonomen
Sun Mar 27 2011, 10:18PM
The power rating of the moniter gives you a hint. Anyways that core is somewhere between ETD39 and ETD50.
ZakWolf
Sun Mar 27 2011, 11:02PM
I have a ton of these what can you use them for ? high voltage or a power supply?
James
Mon Mar 28 2011, 01:12AM
Most CRT monitors consume about 100W in operation. I've measured my 22" CRT at anywhere from 80-120W depending on resolution and what's on the screen. These transformers are almost always run in flyback topology supplies which accounts for their relatively large size for the power level. They are nice big cores though, should be good for a few hundred Watts driven push-pull. Useful for all sorts of power supply applications, the output voltage only depends on the secondary turns count.
ZakWolf
Mon Mar 28 2011, 01:27AM
so could i wind a coil and put it onto the middle part of the E core and add some primary windings on one of the other sides?
Dr. Slack
Mon Mar 28 2011, 07:40AM
No, because then the other side would be magnetically shunting the windings. If you have to ask the question, then you probably won't understand the explanation of why it's bad, but this type of shunt would be bad.
You *could* put it on the middle part of the E core and add two identical primary windings, one on each of the other legs. This reduces the length of copper needed slightly, but that's rarely the most important loss in the transformer. It gives you a little flexibility in that the primaries can be used in either series or parallel, but you must use both identically, you cannot drive them in push-pull, as they're not coupled properly.
A transformer wound like this will have singnifcantly poorer coupling (which is bad) than the conventional way of winding it with both primary and secondary on the centre leg. If you put two primaries on in the conventional way, you would still have the series or parallel flexibility, *and* you could drive them push-pull if you wanted to.
James
Tue Mar 29 2011, 12:44AM
Why not just wind it the way it was originally wound? Insulate the layers adequately and you should be fine. Alternately you could make a partition to divide the bobbin and place the two windings side by side, that's a common technique for providing improved isolation.
