  • Guests: 36
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Basic Magnetron Question
Ash Small
Sun Mar 27 2011, 08:46PM Print
For some time I've been toying with the idea of experimenting with magnetrons.
Obviously, these are/can be dangerous, so I want to reduce the risks as much as possible for my initial 'trials'.
I'm thinking, if I take a complete microwave oven circuit and replace the ~1 microfarad capacitor with a 0.01 microfarad capacitor, this will reduce the power from ~1000 Watts to ~10 Watts.
Will this make it 'relatively' safe?
Any comments or suggestions?
Sun Mar 27 2011, 08:48PM
I have seen this done on Youtube, and yes it appears to work, the magnetron still does something but the power seems to be much reduced.
Disclaimer: I have seen a lot of crazy things on youtube. smile
Ash Small
Sun Mar 27 2011, 10:19PM
I did read that someone had 'replaced the 'series capacitor' with a smaller one, in order to run the magnetron in CW mode' (Doug Coulter, coultersmithing.com), but I think the one he used was around a third of the capacitance of the original.
It took me a while to realise what he meant by 'series capacitor'. I always understood it was part of the voltage doubler circuit.
I'm just extrapolating this to it's logical conclusion, if it is small enough, as well as being able to run the magnetron CW, it will be 'safe'?
EDIT: ie, you could regulate the output of the magnetron by using a variable capacitor.
Sun Mar 27 2011, 10:37PM
Ash Small wrote ...
Perhaps you should think of health risks being proportional to power density rather than overall system power. Might not a focused beam of 10W be more hazardous than a diffuse emission of 1kW?
Ash Small
Sun Mar 27 2011, 11:10PM
You have a very valid point, PM. The 'containment system' used by Doug, Carl Willis and others has two apertures 1/2 inch to 3/4 inch or so, where the quartz tubing enters and exits the shielding. (At least, as far as my present understanding goes, and from the photos I've seen)
This presumably allows the microwave radiation to escape. (Although I understand that microwave radiation (RF) doesn't escape through 'holes', but does escape through 'slits', I believe this phenomenon is related to wavelength, but I'm not certain)
These are some of the reasons why I'm asking for comments (This is an 'electromagnetic radiation' forum)
EDIT: I apologise if this post seems 'vague', I'll be sober in the morning.
EDIT 2: What precautions do you suggest I take to avoid this scenario, PM?
EDIT 3: I'm planning to obtain a microwave leak meter thingy.....any other suggestions?
James
Mon Mar 28 2011, 01:23AM
I would power the filament from a separate transformer and use a variac to control the one providing the HV.
I know a guy who has used a magnetron as a hand warmer, it's a radio transmitter, not ionizing radiation, but I would still advise caution. I've never received a serious RF burn, but I hear they're extremely painful and a magnetron is certainly capable.
Mon Mar 28 2011, 03:08PM
Ash Small wrote ...
Hi Ash, you may find this basic intro to slotted waveguides helpful:
Ash Small
Mon Mar 28 2011, 05:59PM
Thanks, PM. This page from the guide you linked to seems to contain some useful info relevant to this project:
Most of the rest seems to relate to radar arrays (I think)
EDIT: This is a link to Doug's page on the subject. It may give you a better idea of what I'm hoping to achieve. (I believe it's been added to since I last read it)
BTW, I'm not planning on ionizing deuterium. I'm more interested in protons, and some other plasmas.
Mon Mar 28 2011, 06:49PM
I've seen Coulter's pages before. He is a talented constructor.
Ash Small
Mon Mar 28 2011, 09:17PM
I'll post this link on microwave hazards:
(Doug is clever, but he is too 'wordy'....And he never answers questions directly.)
