  • Guests: 42
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
900v
Microwatt
Sun Mar 27 2011, 05:26PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
Does anybody have any good circuits to make 900vdc from 12vdc. I am looking for a minimum of components
Dr. ISOTOP
Sun Mar 27 2011, 05:53PM
Drive a standard inverter circuit with a nice ferrite transformer in it.
How much power are you looking to get?
Microwatt
Sun Mar 27 2011, 06:34PM
10 watts. what is a good inverter transformer. can i use a ferrite toroid?
Sun Mar 27 2011, 09:26PM
A flyback converter - single switch, gapped transformer, diode, a filter capacitor and voltage feedback from the output controlling the duty ratio.
Adam Munich
Mon Mar 28 2011, 02:57AM
A CCFL inverter ought to do just fine, and they cost only a couple dollars to boot.
James
Mon Mar 28 2011, 04:50PM
Depends on what you're trying to do with it. CCFL inverters are (relatively) constant current sources and have a lot of compliance. The output voltage is AC and will drift way higher under no load. This may be fine, but if he wants a regulated source of 900VDC it won't do.
