  • Guests: 49
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
140.000V (140KV) High voltage power supply
radhoo
Sat Mar 26 2011, 08:49PM Print
Now that the title caught your attention, here's a video showing this neat supply and the juicy 14cm length continuous discharges:
The schematics:
1301172460 1938 FT0 Glass3
Construction details / other details available here: Link2
Some pics:
2 4
Hope you like it, actually I know you will cheesey
Turkey9
Sun Mar 27 2011, 05:47AM
Very nicely done!!! Do you have any other measurements for voltage other than spark length and calculations?
Robert2
Sun Mar 27 2011, 07:41AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
140KVDC is ~ 20Cm spark gap...
Sun Mar 27 2011, 11:39AM
So, are these the Glassman high voltage multipliers you talked about before? Good to see you got them working.
radhoo
Sun Mar 27 2011, 02:06PM
Steve McConner wrote ...
Yes, finally I got some time to make a test with them.
I'll also need to use the voltage dividers inside, to connect two voltmeters (one for each multiplier).
