  • Guests: 48
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Modding MOTs, Need Advice.
Sat Mar 26 2011, 05:21AM Print
I need help making some decisions regarding my most recent MOT aquisition.
Background:
I have determined the "as manufactured primary" is 103 turns, the label stated 120Vac, at 60Hz. I presume from its size I can get 1500W out of it. The primary consists of 14 awg mag wire. Magnetic shunts have been pressed out. The intent for this MOT is to use a common setup with a variable turn secondary.
Math:
Given the label said 120 Vac, and I believe from size that 1500W is doable,
Power: 1500 W / 120 Vac = 12.5 A
V per T: 120V / 103 Turns = 1.16 Vac per T
Question 1:
After reading the HvWiki and talking to others, I have wanted to take the core out of saturation, by increasing the primary turns. So, do I just increase the count by 10% or some other number? Or should I measure the input current while adding turns?
Question 2:
Now that I have removed the magnetic shunts, and increased the turns for the primary, will ballasting be easier/different? (By theory im thinking I should stilll need the ballast)
More Math:
If I want 12.5 amps at 120v then,
120 Vac / 12.5A = 9.6 Ohms total impedance (ohms + reactance)
(valid if the secondary is pulling about 1500W)
If I assume 0.3 Amps magnitizing current, then:
120 Vac / 0.3 Amps = 400 Ohms total impedance (ohms + reactance)
(valid at no load on secondary)
Logical Conclusion ?:
Should I choose to increase the primary turns such that 12.5 amps can still pass through that reactance, with the difference between that and 9.6 ohms being made up with the ballast? I just dont want the Volts per turn to drop much below 1.0 or
0.9 Vac.
EDIT:
I appologize if previous threads dealt with these matters in detail, using our search function before posting this, I found nothing useful enuogh, but I will remind all that our search function is basically crap.
1301116867 2431 FT0 Mot Crop
Secondary and shunts removed.
1301116867 2431 FT0 Mot2
MOT in a vice and the spool I will use to lengthen the primary.
1301116867 2431 FT0 Mot3
Beer bottle for scale.
1301124675 2431 FT1630 Mot4dim
Dimensions 3.45" x 4.14" x 2.4"
haxor5354
Sat Mar 26 2011, 05:44AM
does transformer steel have a magnetic flux limit like ferrite?
Sat Mar 26 2011, 06:08AM
haxor5354 wrote ...
Yes, it does, but steel is higher. Ferrite is about 0.3T, steel is like 1.3 -1.7T, under common conditions. If I remember right.
Sat Mar 26 2011, 10:13AM
Your MOT could have magnitizing current of ~4 Amps and a no-load input of ~100 Watts. It will get VERY hot operating even at no load.
If you want to use a MOT for continuous work, you should add a fan or increase the primary turns by at least 20 percent.
As to your question 2, if you need a low internal resistance power supply you should not use any ballast.
Marko
Sat Mar 26 2011, 04:42PM
If you find ading more primary turns troubling, you could use a buck transformer in series with your input. A transformer of 100-150Va with 12V output or so can be conencted to mains and it's secondary in series with supply to your mot, in anti-phase so it reduces the voltage on it. It might be easier but not more cost and space efficient, though.
Marko
Sat Mar 26 2011, 05:16PM
I applaud Marko's suggestion of using a buck transformer to reduce the volts/turn, magnetizing current, and core loss. You would look for a 120 to 12V or 24V transformer with -secondary- current rating at least as high as your intended primary current in the MOT. Ubiquitous for low-voltage lighting systems.
Why bother reducing the volts/turn, unless you want to run for more than 10 or 15 minutes without a cooling fan?
You can calculate the peak flux density (B) directly from
1) sinusoidal RMS volts per turn [edit] per hertz.
2) cross-sectional area of the core - the center leg should be twice the area of the outside legs.
Write back if you need a reference, or want your numbers checked.
A few months ago I reported on an XRT with peak flux of over 1.8 T, which is exceptionally high for steel cores except those for intermittent use. MOT's might be similar.
[edit] p.s. I recently investigated the behavior of transformers near saturation, with a resistive ballast in series. You can actually get significantly more RMS volts per turn for a given RMS magnetizing current, as the voltage waveform distorts (in the direction of being peak-y rather than square-ish). No time to elaborate today.
Sat Mar 26 2011, 07:21PM
This was exactly the response I needed:
Dr. Kilovolt wrote ...
Well OK, the 4 amp thing at no load is a real downer. sad I removed the shunts to make it function more ideally. I will use resistive ballast on the primary for test/evaluation and proving. Then Ill switch to inductive ballasting on the primary or secondary.
It will be inside a well cooled case, but I was hoping to keep them cooler for 10 -15 minute runs. I will add 25% on the primary's turns.
I was planning on this type of usage: 15 mins on, 30 mins off, for several hours at 80% of max capacity with continuous cooling.
Im not sure what the heat load would be, ill have to run some tests.
Nah
Sat Mar 26 2011, 09:08PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
I added around 15 turns to mine and had a load of 100 watts at 10 volts. It didn't even get warm.
Sat Mar 26 2011, 10:09PM
Nah wrote ...
How long did you run it?
Sat Mar 26 2011, 11:14PM
The core can take up to 3 hours to get up to temp.
