  • Guests: 42
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
10/31 Stuff (43)
555 plasma speaker problem
magnet18
Thu Mar 24 2011, 04:02AM Print
Hi everyone,
I'm currently attempting to build a plasma speaker using a 555 timer, an IRFS654 MOSFET, a lead acid battery, and a flyback; from what I gather it's not an uncommon procedure.
My problem is that the frequency coming out of the flyback doesn't seem to match the 555's frequency. I scoped the 555 pin 3 as being 25 kHz, which is well beyond audible, but when I attempt to create an arc it makes a nasty tone approximately that of nails on a chalkboard, and the plasma arc is erratic and jumps about. Also, as I change the distance of the spark gap, the frequency changes audibly, growing lower as the distance is increased and higher as the distance is decreased. I have tried this with both 20 and 10 turns on the primary and got the same result, with the 10 turn's providing more voltage, but the same effect.
Does anyone know where I might be going wrong?
I can post a pic/video of my setup if anyone thinks it will help.
Thanks in advance :)
ZakWolf
Thu Mar 24 2011, 06:22AM
i built the 555 timer plasma speaker with very poor results. The sound quality was like you described "like nails on a chalk board" with very quiet music in the background. Your better off making the tl494 driver Link2 or my favorite so far the sg352a driver Link2
good luck ;)
James
Thu Mar 24 2011, 05:44PM
LittleVenture wrote ...
good luck ;)
What's with the 10,000uF lytics? I've never seen capacitors anywhere near that large used with a half bridge like that.
magnet18
Thu Mar 24 2011, 07:53PM
I tried those, couldn't get either of them to work, but I intended to build grenadiers in the future.
@James, I believe they must be so large to ensure that they can supply, absorb the power required to drive the flyback.
James
Thu Mar 24 2011, 08:50PM
I'll have to try the circuit and see what happens with smaller caps. 1-2uF ought to be enough, and generally using polarized lytics in applications like that is unwise.
ScotchTapeLord
Thu Mar 24 2011, 11:23PM
10,000 uF is overkill for the half-bridge midpoint tap, but the types of capacitors he is using probably aren't rated for enough current, so paralleling them will help. But the proper thing to do would be to use higher current capacitors. Also, they need bleeder resistors.
Also not sure how I feel about the polarized capacitor on the *AC* audio input.
magnet18
Fri Mar 25 2011, 01:11AM
ScotchTapeLord wrote ...
He's a member of this forum, and I noticed that he had the cap polarized backwards on the pictorial schematic, generally the negative goes to the AC audio while the positive goes to the chip, which is generally positive. I personally used a nonpolar cap.
In any case, I reduced the turns and doubled the voltage on my 555 circuit and it seems to be doing fine, apparently one pulse was too short to build up enough charge to jump the gap.
ZakWolf
Fri Mar 25 2011, 01:27AM
I used the parts he said to use and it works just fine, the 10,000uf caps never ever get warm either.
**The heat sink in the pictures is totally unneeded, i thought there was going to be a lot of heat from the fets. Maybe the heat is so little because i am using an lm7812 instead of an lm7815 which i will replace when it arrives for better output and sound quality.**
1301016426 3114 FT111445 Dsc00402
1301016426 3114 FT111445 Dsc00404
James
Fri Mar 25 2011, 05:37PM
I'm sure it would work, I'm just wondering if some small film caps would work as well as the big relatively expensive lytics. I have loads of smaller caps.
Fri Mar 25 2011, 08:43PM
The divider caps value goes up with inverse square of the supply voltage, so if you use 1uF with 320 volts you need to use over 100uF at 24 volts, and film caps of this value are really expensive and large...
