  • Guests: 34
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Best op amp to use as buffer?
big5824
Thu Mar 24 2011, 07:44PM Print
I know this should be a relatively simple question, however i hate op amps and op amps hate me, and thus they always seem to break in seemingly impossible ways. So i figured I should just ask here, can anybody recommend an op amp for me based on their experience?
The reason I need them is to buffer the 180Kohm impedance signal from a gyroscope so that it can be quickly read by an adc. Its range will be pretty much 0-5v, and must run off a 5v source and ground.
thanks in advance guys :D
Matt
/edit
Just though i should add, its vital that the amplified signal is pretty much exactly the voltage im putting in, less than 0.5mv if possible
James
Thu Mar 24 2011, 08:43PM
For that sort of thing there is very little difference between one op amp and another. The supply voltage will be your biggest hurdle, so you will want to find one spec'd as "rail to rail", ideally designed for a single 5V supply. Check out Link2
How are they breaking? Op-amps are usually quite robust and simple to use.
Thu Mar 24 2011, 09:30PM
My go-to rail-to-rail op-amps are the LMC6481/2/4 (single, dual and quad). I've built dozens of precision analog circuits with them that run off a single 5v supply. The A grade has about 0.5mV offset.
I used to use the LMC660, but it's getting pretty ancient, only available in a quad, and very probably won't meet your 0.5mV spec.
Op-amps hate you because you murder them. smile
Avalanche
Thu Mar 24 2011, 10:57PM
MCP604 seems to be what I go for, rail to rail 5v. It's probable going to be the 2n3055 of op-amps
Don't forget to save all your non-operational amplifiers in a drawer labelled "non-operational amplifiers" smile
2Spoons
Fri Mar 25 2011, 01:20AM
Its also important to check that the opamp is unity gain stable. You also haven't specified bandwidth, or the load presented by the ADC.
big5824
Sat Mar 26 2011, 01:32PM
Bandwidth is 1khz, which i assume any op amp can handle with ease, and the adc requires an input impedance of less than 10Kohm, which again i thought most op amps could easily handle.
Im currently thinking of using Link2
any thoughts?
Sat Mar 26 2011, 03:42PM
I have very good experience with the LT1013 opamp. Link2
