  • Guests: 67
Barry (71)
Snowcat (38)
wylie (44)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Nixie clock
Dr. H.
Sun Mar 20 2011, 07:25AM Print
Good day guys
a good friend of mine donated 12 z570m tubes and I decided that it is finally time to realize one of my all time dreams - build a Nixie clock. Nothing special - it is controlled by pic16f877A and it has a simple boost converter for the B+. Here some pics - hope you like it guys. Cheers smile
1300605870 931 FT0 Dsc05587
1300605870 931 FT0 Dsc05593
1300605870 931 FT0 Dsc05604
James
Fri Apr 01 2011, 03:16AM
Nicely done. I need to build some more nixie clocks one of these days. I have some nice VFD tubes I ought to use too.
Thu Apr 21 2011, 09:41AM
Trying to build one at the moment.
It appears that the MMBTA42 is the best bet for compact Nixie clocks, as these can be placed on a board under each tube which makes the whole assembly nice and compact.
-A
Dr. H.
Thu Apr 21 2011, 11:59AM
Good day Conundrum
I used the TO92 equivelent - the MPSA42 ... dirt cheap and work OK smile
Cheers
Thu Apr 21 2011, 03:52PM
Nice work Huben! Always loved the quality and workmanship you always tend to put in your projects.
James
Thu Apr 21 2011, 04:55PM
I've used the MPSA42 in many of my clocks. There's also a Toshiba octal HV transistor array that I've used several times with success. It's nice because if you flip it around so pin 1 is in the opposite direction, you can place it almost right next to a 74HC595 and the connections are straight through.
