  • Guests: 22
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
What do you usually do when you're going to plug something in the wall?
Inducktion
Fri Mar 18 2011, 08:50PM Print
When I say plug into the wall, I mean something YOU built.
I recently made Link2
from neon-john's website, and it works on 12 volts on both sides. I'm deathly afraid of plugging it into rectified mains, though, I'm worried something might go wrong or die.
What do I do to alleviate this problem? I worked quite a while on this so... Worried to lose it all.
The isolation transformer on the schematic has 16+16 turns for the primary and some 8-9 turns on the secondary.
Primary is 12 gauge wire, and the secondary is speaker wire, with both wires soldered together to make 2 strand litz.
The diodes on there, the RPG02 ones, I switched out with UF4007 diodes, and the inductor to the left is actually around 165 uH instead of 200 uH.
Everything else is exactly how it is on the schematic.
James
Fri Mar 18 2011, 10:17PM
Put a lightbulb in series with it. Start out around 60W, if all goes well bump it up to a 100W bulb. Ideally you would scope the current waveform on the primary side of the transformer. A small ferrite toroid with 10-20 turns with the wire you want to measure passed through the center of it will work reasonably well. When you go to run it directly, be sure to use a 10A fuse of at least 250V rating on the input.
Edit:
Isn't the transformer supposed to have 8+8 (16 total) turns? Too many turns is better than not enough turns at least.
Inducktion
Fri Mar 18 2011, 11:08PM
James wrote ...
Edit:
In his original one he used some 20+20 turns for the iron powder toroid transformer....but I'm using ferrite so 16+16 is probably about right. And like you said, too many turns is better than not enough, otherwise too much current would flow and pop my IGBT's.
And alright, I'll shakily try and use a 40 watt lightbulb, probably will bump it up pretty quickly if it works well. Thanks for the advice.
haxor5354
Sat Mar 19 2011, 04:08AM
take it outside with a really long extension cord and a remote controlled relay switch to turn it on. the worse thing that could happen is your device blowing up.
Turkey9
Sat Mar 19 2011, 05:16AM
Did you test it with an isolation transformer for the high power input? If so you're basically already done the light bulb step using the transformer's power rating to limit the input current.
Sat Mar 19 2011, 05:23AM
If you can give the core cross-sectional area,
the value of the primary resonant capacitor
and the frequency that it runs at on low power
we can calculate whether the core can operate at rectified mains voltage, or saturate.
Do you have a variac?
For this circuit ALWAYS apply the low voltage supply before the high voltage,
and disconnect the low volage supply after the hv has been removed,
or you may blow your transistors.
If the dc inductor saturates you will get hard- (not zvs-) switching which also may kill your transistors.
Dr. ISOTOP
Sat Mar 19 2011, 01:39PM
Variac it up.
Inducktion
Sat Mar 19 2011, 05:10PM
Sulaiman wrote ...
I don't entirely know what happened. I had it all hooked up right, with the low voltage applied before the high voltage like you stated. I had it current limited with a light bulb, and it worked. Without it, the IGBT's went BANG and little bits of silicon flew everywhere. It was rather violent, and even some bit of the trace on the board I made came off. I assume, then, that something caused too much current to flow and thus kill my IGBT's.
And the core is a medium sized flyback core taken from a TV. The resonant capacitor is .15 uF. It ran at about 45 khz on low power. The DC inductor was a 155 uH powdered iron core, two taped together. Yellow color.
Sat Mar 19 2011, 05:23PM
When testing something new I will have fuses built in that will go before the mains fuse on that line. I also use a variac to slowing increase the voltage. I also have a scope on the critical signals to make sure nothing is going awry.
At this point I will either
1. see the problem and abort before destroying the project
2. the project will blow, but the fuse will protect the line.
Make sure you are protecting your eyes if you think a capacitor or semi might blow.
Sat Mar 19 2011, 08:04PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Variac or a long wood (dry) or plastic stick.
Martin.
