  • Guests: 28
Will (38)
Arlecchino (41)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
Sanken Electric part numbers.
Mon Mar 14 2011, 03:30PM Print
Am i the only person who always comes across the SK SMPS ICs which apparently have no datasheet? I like these ICs, it is comparable to a typical current mode controller like the uc3842 with a power mosfet inside.
Anyway, the specific IC i have right now which i want the datasheet for is called the STR-Z4517. Here is the AC/DC converter lineup: Link2 Keep in mind, this power supply which the IC is mounted is from, what i believe was an LCD TV, so it must be a fairly new IC. Here is a datasheet for a similar SK IC, mine is in a similar package but with 14 pins.
I have more ICs from Sanken, though, all starting with STR-, and very few times kind i actually find the datasheet. Does anyone know some kind of way to get a datasheet? Perhaps an eMail, but considering the size of the company, they may not bother replying. Any thoughts?
