  • Guests: 47
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Rifle based ETG
1 2 3 4
Killa-X
Sun Mar 13 2011, 01:28AM Print
I thought I might as well start sharing my project, and progress as I go.
* Capacitor Bank: 450V 9600uF for roughly 980J of power
(May hook it for 900V, not sure)
* 800V 350A Stud Diode
* 1200V 650A SCR (I want a STUD)
So. The scope of my project, I wanted to make a Rifle based ETG. That way I have a barrel which will give the projectile enough time to accelerate. In the past, I did PVC pipe. 12 inches long. I manage to shoot a flash capacitor through the bottom of a soda can. The next shot exploded the PVC plastic adapter. Due to this, I moved to solid steel tubing. This is 4mm thick steel pipe, with a threaded endcap. Weakest point, the threads. 1KJ should be fine for this system. JUST IN CASE it explodes, I understand metal is lethal at high speeds. I am placing the endcap inside a 2" diameter 4mm thick steel tube. The side facing me, the gun holder, will have a 1/2" steel plate welded to the pipe. So, my PVC system had a lot of leaks. This is air tight. It should shoot a LOT better.
Now. Why am I making an ETG? Obviously not to do harm to life (people..animals..etc). The reason I'm making an ETG is for three things.
1) To have it as a proof of concept
2) To present it to my electrical teacher, Showing how you can make a gun with capacitors and foil (points to number 1)
3) To mess around with, meaning to shoot it at targets, just like someone does with a spud gun.
I understand the dangers of weapons, and rules against making such things. I am one who takes saftey as a priority, and design things so when stuff goes wrong, I'm safe. I also tend to enjoy putting way too much money into looks. I'm even buying a full metal 1:1 scale replica of a handgun for a handle =)
PICTURES!
* Barrel with capacitors
* Muzzle for looks (Sound dampening too)
* Protection pipe to shield myself in case of explosion
* Test design front view
* Cad design (The stock sucks, I know, I'm still working on it
Let me know what you think! Will update as things are made.
[Edit: F. Any images you include in your post must be less than 400 pixels wide. If the image is too large, link to it with a URL tag rather than actually embedding it with an IMG tag. If it's something you intend to attach to a post, the board will automatically resize it for you, and create a link to the full-size image. Offending images may be removed at any time -- if you post oversized images, don't be surprised or angry if you find all your images deleted. ]
HazzWold 1993
Sun Mar 13 2011, 09:59PM
None of your pictures show up for me :(
Killa-X
Sun Mar 13 2011, 11:13PM
HazzWold 1993 wrote ...
On some kind of mobile? They are just imageshack..Usually works fine in any location you got internet... rolleyes
HazzWold 1993
Sun Mar 13 2011, 11:41PM
At a library, on Windows 7, IE8..
Killa-X
Mon Mar 14 2011, 02:47AM
Ah. Weird they block sites probably I guess. Maybe at home you can view it fine hopefully.
Well, I did some tests today and it failed. I was able to blow the projectile out of the barrel at a slow rate with little breath, or fast with lots of breath. When i did 400J, nothing came out. So...I think the issue was the wire. I made this quick with what i had, 20awg wire. Before you go OMG REALLY?! ON 1KJ?!?!?!?! Yeah. I know. But it last 3 shots, and the contacts (touching the foil) was all gone.
I'm hoping the gun sucked DUE to the contacts evaporating. And that it works better when i get 12awg. Hopefully!!!
HazzWold 1993
Mon Mar 14 2011, 06:56AM
I can see it now! at home.. btw nice work!
cedric
Wed Mar 16 2011, 09:24AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
the coil is around the iron barrel ?!!
Electroholic
Wed Mar 16 2011, 10:22AM
I'm in the middle east, and the pix are not working for me.
Try imgur next time.
Wed Mar 16 2011, 10:23PM
OOooooo! Killa-x nice work! I need one of these, I even have an pellet rifle plastic grip-stock from a dead weapon. I will repurpose it for this device.
EDIT: I could be persuaded to part with 8 of my 50RIA60 (600V) SCR's. not sure if they meet your specs though.
EDIT: The pics show up fine for me.
Killa-X
Wed Mar 16 2011, 11:16PM
cedric wrote ...
Its an ETG. Electrothermal, shoots with plasma by evaporating foil with high capacitance.
Well I need to buy a new barrel because a weld seem down the inside of the barrel is causing issues. I got something in mind but no idea if regular plumbing parts will fit on conduit...The thick wall threaded ones
