  • Guests: 39
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Zero budget mini ion ray gun
flannelhead
Sat Aug 25 2007, 09:30AM Print
Hello there!
I want to show you my minimalistic project I finished yesterday. It's a mini ion gun, made mainly from disposable camera components. It's zero budget because I already had all the stuff I needed for it! :)
Some technical info:
-Power source: one 1.2V AA 1200 mAh NiMH rechargeable battery (normal 1.5V non-rechargeable ones work also)
-Inverter: the transformer from a disposable camera with its driver (220 ohm resistor and 2SD2504), puts out 330V
-Voltage multiplier: 6-stage CW made from the small capacitor and diodes from disposable cameras, diodes are configured for positive output. Capacitors are 2nf (I suppose)
-Limiting resistor is 10 Mohm
-Discharge point is just a sharp needle
-Grounding: user (the grounding wire in the handle is seen in the pics)
The gun was assembled, of course, with hot glue (I love that stuff :)
Schematic for the inverter was found here http://www.increa.com/reverse/dc/dcschem.gif, although my cameras were blue fujifilm ones, not kodak.
The performance was surprising when I tested it first time. I could feel the ion "wind" ~7 cm from the discharge point. It can also stick some small pieces of paper (4cm*4cm) to the wall for ~ten minutes. It gives some arcs of max. 5mm. Not bad for as simple device as this is, or what do you think?
Here's some pics of the gun:
Overall
Top View
Back View
Another Side View
Side View
Arc
And some video (wmv format because I hadn't got time to mess with mpeg2 encoders :(
The arcs are 5mm or something
1188034147 952 FT0 Overall
1188034147 952 FT0 Top View
1188034147 952 FT0 Back View
1188034147 952 FT0 Another Side View
1188034147 952 FT0 Side View
1188034147 952 FT0 Arc
]1188034147_952_FT0_arcing.wmv[/file]
All comments are welcome! :)
Capper
Sat Aug 25 2007, 01:35PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
You may get better output if you make the end terminal negative. I made a similar device using a disposable camera power supply attached to an automatic spark unit for a gas stove.
Scott
flannelhead
Sat Aug 25 2007, 03:05PM
Capper wrote ...
Scott
I've tried both, negative and positive output but the positive seems to be more powerful. I don't know why is this, but the positive just works better.
Spedy
Sat Aug 25 2007, 06:54PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Wow! this is awesome. A bike ride down to target is a lot cheaper than $50 from Information Unlimited. It probably has more performance, but this little thing you threw together is COOL. I'm definatly going to build one of these some time :)
I'll give this project 11/10 for being budget-friendly and effective, not to mention looking plain cool. cheesey
sparky
Sun Aug 26 2007, 12:34AM
Very cool! I like this project you built :) I bet it tickles if you touch the output :P
flannelhead
Sun Aug 26 2007, 08:10AM
Yep, it tickles somewhat, and it can give you an rf burn if you put your finger close enough ;) If you're gonna build this, remember the 10M resistor on the output. If you forget this, the CW will give you a very nasty shock :(
CT2
Tue Aug 28 2007, 05:45PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
Your 10M resistor looks a little small (physically) for that voltage... it might arc over when you touch it and then you'll get the full shock.
Josh
Wed Aug 29 2007, 01:31AM
Josh Registered Member #938 Joined: Sat Aug 04 2007, 05:39AM
Nice!
I have a small 15 kv supply but I want more power so I'm going
to do what you did. I give it a 10/10 too cheap,fun and easy :)
Also what type of diodes and there ratings ? I may get some along with
my order and some capaciters then I will need one camera
Spedy
Wed Aug 29 2007, 03:05AM
Oh, about the positive output thingy, I find that If I use HV in +DC output I get all quesey. Maybe its just me, but I prefer -DC as it doesn't do this too me.
Just my $0.02
Bjørn
Wed Aug 29 2007, 04:25AM
It could be that you get more ozone when using the positive output. Ozone can make you pretty sick.
