  • Guests: 41
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Will I be able to charge a Lipo
LIGHT
Wed Mar 09 2011, 07:56PM Print
LIGHT Banned on 4/6/2011 for unsafe, irresponsible behavior.
Registered Member #3442 Joined: Fri Nov 26 2010, 04:09AM
Can I charge a Lipo without the real charger, I want them as a PS, they are 7.4v out, and it says 9-12volts in to charge, can I charge them with a wall wart of something similar?
LIGHT
Wed Mar 09 2011, 08:51PM
will it blow up?
Inducktion
Wed Mar 09 2011, 08:58PM
walshy155 wrote ...
will it blow up?
It depends, most, if not ALL lipo batteries need to be charged used a special circuit. Charging it with a wallwart will almost guarantee something bad happening, most likely the battery exploding and shooting flames....Play it safe, I assume you've seen what happens to overcharged lithium batteries on youtube.
LIGHT
Wed Mar 09 2011, 09:03PM
well it says 9-12v in, and I opened it up, and it has a built in circuit. What can I charge it with?
Thanks for replying.
Wed Mar 09 2011, 10:47PM
you have to do some math, the volts per cell is determined buy the chemistry, so youll have to look it up, the complex and very good chargers are putting out the cell charge volts to 2 decimal places, like 4.XX Volts per cell.
it does vary a little bit give the Charge and Discharg rate C.
Bjørn
Wed Mar 09 2011, 10:49PM
Your answer is as good as ours, without knowing the exact model we don't know. We can only tell you that if you do it wrong you might start a fire.
Start by giving us the name and model of the battery and include links to everything.
James
Thu Mar 10 2011, 12:51AM
Usually the circuit in the pack is a protection circuit. It will cut off the charging cycle to prevent catastrophic failure, but it will still allow the cells to be overcharged. In a pinch you can make a Li-ion charger with a LM317 and a few resistors. Really though you're better off making a proper charger. You can probably even get the chip as a free sample.
Electroholic
Thu Mar 10 2011, 09:13AM
The easiest way to charge is a CCCV cycle. Constant current until a voltage setpoint, and then constant voltage until current drops to a certain level. Exact current and voltage will depend on your particular cells. And then there is balancing...
In a pinch, I've used an HP bench powersupply to charge my cellphone. Carefully setting the current limit and voltage limit and double check with a calibrated fluke.
LIGHT
Thu Mar 10 2011, 02:55PM
I dont know the battery model, but it's from this > Link2,114/
I plugged a PSP charger into it, and the 'charging' LED lit up, although it was below stated charging voltage.
I opened it up, and it has two cells.
Electroholic
Thu Mar 10 2011, 03:04PM
What kind of cells? pouch type lipo or 18650?
you can by a charger for 18650cells for like $20.
