  • Guests: 31
Will (38)
Arlecchino (41)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
Leakage Inductance EHT transformer...
Nicko
Mon Mar 07 2011, 04:55PM Print
Continuing the clearout, I have found a heavy "Leakage Inductance Transformer"...
It is massive, has one primary (10-0-200-220-240V @ 50Hz) and two secondaries - 0-6.3V @ 300mA RMS normal regulation, and 0-5400V RMS (open circuit)/220mA RMS short circuit... about a 8 inch cube and weighing in at about 30 lb.
Apart from scaring people, could someone explain what differentiates a "Leakage Inductance Transformer" like this from any other sort of normal transformer...
Edit: Getting a bit further on this - the HV secondary is deliberately separated from the primary to increase leakage, thus this turns into a sort of "constant power" transformer with max voltage at 0 current and max current when shorted - it will be short-circuit proof...
So I should get 5400VAC with little current draw and about 220mA when shorted, so assuming linear derating (which is a bit generous) we are looking at about 300VA.
Now I just need to come up with something to do with it. Other than land-fill, that is...
Thanks
Mon Mar 07 2011, 06:41PM
Nicko wrote ...
Do you have a boat that needs to be anchored somewhere?
Sounds like a behavioral big cousin of the NST. Can you tell if the core is shunted between the primary and secondary windings?
Mon Mar 07 2011, 08:43PM
It's not a constant power transformer, the output characteristics should be the same like if you connected a choke/inductor in series with the transformer's primary winding.
The maximum output power into a resistive load will be more than VA/4 because with a series RL circuit the voltages form an impedance triangle (they do not add up...)
Nicko
Mon Mar 07 2011, 09:27PM
There just seems so little out there on these beasts. This one was used in an old ion pump for high vacuum lab equipment - I'm informed that any others like this are only likely to be found in the Cavandish Labs darkest & dustiest storerooms...
Still looking for a use for it, though...
Mon Mar 07 2011, 09:59PM
Make a Jacob's ladder? tongue
// or a SGTC, etc... It is just your normal current limited HV transformer.
