  • Guests: 35
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
High Speed movie of my new Pulse Laser Gun 1MW
Zero
Sun Mar 06 2011, 07:30PM Print
Zero Registered Member #3588 Joined: Sat Jan 08 2011, 11:19AM
Power and looks...my best work so far...imo wink
Mon Mar 07 2011, 12:47AM
Captain Kirk would be proud of you !
Adam Munich
Mon Mar 07 2011, 03:55AM
Details on the laser itself?
Zero
Mon Mar 07 2011, 11:19AM
I prefer Picard to be honest wink
Its a SSY head. Bigger lamp. I hate realigning mirrors, so the SSY is the best choice.
haxor5354
Sat Mar 12 2011, 03:12AM
how the the battery even provide 1MW?
dmg
Sat Mar 12 2011, 03:43AM
It doesn't.
Its a pulsed ND:YAG system as he says, you dont need a large power source in order to pulse a flashlamp or a pump diode array to drive a yag into very high powers.
So the differance here is a Q-switched pulsed laser, if you were to use a CW system you will definatly need a larger setup and a bigger power source (I think the current record for a CW system is 100KW output).
Zero
Sun Mar 13 2011, 02:04PM
CW YAG would be ccool though. Nice beam ^^
Adam Munich
Sun Mar 13 2011, 08:47PM
Let's see some pics of the insides!
Dr. ISOTOP
Sun Mar 13 2011, 08:56PM
Zero wrote ...
Let's see you pack a 50lb lamp pumped YAG head and its associated 50lb 3-phase power supply into a handheld form factor smile
Diode pumped, on the other hand...but that would cost too much and be a waste of a perfectly good DPSS.
You should go 532 nm green! Visible is so much cooler than IR.
Zero
Thu Mar 17 2011, 09:19AM
Visible would be cooler, but way harder to make and more expensive. The parts for it wont grow on trees.....yet ^^
Grenadier: The only pic I got of the inside, are shown in the video.
