  • Guests: 59
Chicken sticks
Adam Munich
Sat Mar 05 2011, 11:45PM Print
Just wondering what 4HV uses for a chicken stick.
1299368689 2893 FT0 Kol Labe
^That's what I use.
Sun Mar 06 2011, 01:03AM
Hardly a 'chicken stick,' but these Knipex glass-reinforced plastic gripping pliers are what I use when dealing with live wires can't be avoided:
1299373064 543 FT0 Knipex Grp Gripping Pliers Upload
Ash Small
Sun Mar 06 2011, 02:42AM
10mm O/D plastic pipe and insulating tape.
1299379370 3414 FT110102 Chicken Stick
Killa-X
Sun Mar 06 2011, 02:53AM
Well, not really a picture i can use to show the function of my stick. But this is for my tesla coil. It has a breakout point that forces a streamer to kick out the top, and it has a scanner FL =D
genious 7
Sun Mar 06 2011, 03:54AM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
I use pvc pipe with a metal tip at the end, and the wire is a coaxial cable with the outer layer grounded, but only the inner conducting current. There is aquarium tubing surrounding all the cable, from end to end.
quicksilver
Sun Mar 06 2011, 08:27PM
Same: PVC pipe piece of neon-sign lead on the end, etc.
GluD
Sun Mar 06 2011, 08:35PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
Last time i used a "chicken stick" it was in the shape of a broomstick with a wire taped onto it. Simple but it worked ok for the short time it was needed.
