  • Guests: 52
Potential transformers and overvoltage
Sat Mar 05 2011, 09:48PM Print
I have a PT which was used for measuring 22kV 50Hz line voltage phase to ground (so 22/sqrt(3) rated). I was wondering how high a safety margin these are usually designed with. While playing with resonant arcs I think there was a very high voltage surge in one moment, I think my ~8cm wide safety gap fired but I haven't seen it, I wonder if this is safe for the transformer...
mnr
Sun Mar 06 2011, 01:59AM
mnr Registered Member #996 Joined: Sun Sept 09 2007, 06:17PM
I have a GE 120:1 (14.4kV primary) instrument transformer, and it has a BIL of 115kV. Generally if the P.T. was designed for protective relay use there will be a large safety factor built in.
Sun Mar 06 2011, 02:07AM
I agree with mnr's previous statement, there rated for quite abit more then they measure (BIL), for human safety (lightning and such) purposes. I think a simple spark gap shoulD be good enough to ensure a long life for your PT.
Sun Mar 06 2011, 05:00PM
Thanks... I drew arcs for some 5 minutes and it survived smile
dex
Sun Mar 06 2011, 06:35PM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
mnr wrote ...
Regarding PTs' insulation,their peak power frequency withstand voltages are lower than BILs.
