  • Guests: 41
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Add your laser fail here...
Sat Mar 05 2011, 09:31PM Print
Hi all.
Just found this really nice photo on laserpointerforums.
Seems that someone was a bit careless when decanning a diode (looks like a 405, possibly a 445 frown )
Had that happen to me once with a 940? nm cd write laser. In this case the actual semiconductor came apart into two halves!
can sometimes happen with overdriven PS3 diodes as well.
Feel free to add to this thread with pics of laser related oopses.
EDIT:- I've had diodes die due to overheating before, in my case it was a £40+ decanned HD-DVD drive laser.
Ran it in an aixiz but evidently the heat buildup at 72mA caused it to run away and cook.
Module was at about 70C (hot to the touch) when it COD'd.
-A
1299360701 96 FT0 Laser Fail
Adam Munich
Sat Mar 05 2011, 11:51PM
Traded tritium for a 445 diode, got it in the mail and blew it up all of 10 minutes later.
That is why I don't build diode lasers...
haxor5354
Sun Mar 06 2011, 01:53AM
Grenadier wrote ...
NEVER power up a laser diode without a driver. laser diodes run on current, but sometimes you can't have the current without raising the voltage and if you raise the voltage, the current might get too high and deep fry your diode. drivers are suppose to limit the current and protect your diode.
how mant watts was the diode that you traded for? If anything lower than 1000mW I'd rather keep the tritium. atleast they ligh up for 10 years right? and they're cool to have too, how often do you radioactive material aroud?
Adam Munich
Sun Mar 06 2011, 01:58AM
Heh, I used a driver too. It used to be a 1W diode...
haxor5354
Sun Mar 06 2011, 02:03AM
Grenadier wrote ...
didn't heat sink it?
Adam Munich
Sun Mar 06 2011, 02:05AM
Diode died instantly, no heat to be found. My driver must've been dead or something.
Meh, nothing I can do now anyways.
dmg
Sun Mar 06 2011, 04:31AM
Grenadier wrote ...
So did you use a heatsink or you didnt?
What kind of driver did you use for the diode?
btw, the 445 diodes, the A-140/150 series of them can do 2W with good heatsinking.
The A-130's (now discontinued I hear) have a slightly lower wavelenth, and are less efficient so they have a lower output.
Remember.. heatsinks are your friends...
Sinksareyourfriends
Sinkfront
Meatball
Sun Mar 06 2011, 05:00AM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
I've had 445s die on me on first or second power up for no reason at all. Fickle the diode laser is. Very fickle indeed.
Sun Mar 06 2011, 07:24AM
How powerful of a diode can one get for a laser that can do some serious burning?
Sun Mar 06 2011, 11:26AM
3W 808's are fairly common now, see Link2
I believe that 10W blue are in the pipeline as the blue-green conversion is more efficient than 808-1064-green so they have dual application as projector light sources and general purpose spot lighting.
I also discovered something interesting, lasers can be used to make pretty good ready polarised illuminators for microscope+webcam applications.
(DO NOT USE with conventional microscopes!!!!)
Also another amusing application is to couple a red or blue write diode to an optical fibre bundle and make a high efficiency backlight for LCD use.
-A
