  • Guests: 40
Flybacks and Waveforms...
Sat Mar 05 2011, 09:07AM Print
Does anyone know what the primary waveform is (primary wound on ferrite) if driven by a 555? And or/ the Secondary of a diode-split Flyback? Or will I have to measure this myself? A paint Jpeg, or a hand drawn diagram would be a useful approximation.
I presuppose that a square wave in will not equal a square wave out. Also, I expect the primary current to be a rising saw tooth graphed function, with the same voltage would be appraximately square?
Sat Mar 05 2011, 01:24PM
Patrick wrote ...
Primary time constant Ï„ = RL applies. Ï„ will impose its own idea of order on any input 'square' wave and, inter alia, limit the useful upper pulse repitition rate.
Antonio
Look at this, for example:
Sat Mar 05 2011, 02:07PM
Antonio wrote ...
Yes this helps.... but what about a secondary waveform with no secondary side components, whats theV trace like then?
Ash Small
Sat Mar 05 2011, 03:35PM
Patrick wrote ...
Antonio wrote ...
I'm just stating the obvious here, but would the output not just be a spike?
EDIT: And wouldn't the diodes prevent any ringing?
Sat Mar 05 2011, 03:41PM
The simple answer is that, without any loading on the secondary side, the output is "undefined". To a naive first approximation, considering an ideal transformer and ideal switch, it's a spike of infinite voltage and zero duration.
In a more detailed analysis, the switch takes a little time to turn off, the secondary's self-capacitance rings with the transformer's inductance, and the resulting spike is more of a damped oscillation, whose peak voltage is just dangerously high rather than infinite.
Moral of the story: Flyback converters are not designed to be run without a load (or some form of control loop) and will die. Put on a load, and the waveforms change to what you can see in any EE textbook like the link posted by Antonio.
Sat Mar 05 2011, 05:43PM
Steve McConner wrote ...
Your absolutly right, i feel as dumb as a box of rocks.
Yes, this was what i wanted to know.
yes but i really meant what would happen with Zero installed capacity or inductors, just purely resistive, and a duration of kV out much less than that of the off time, all of antonio's and my sources show continuous output V and I. Yet this is not how we operate our HV transformers here on the forum, our output HV is most often discontinuous.
so with only a high voltage resistor in series with the output, what would the graph translations look like? Approximatley a rounded spike that tapers down with time?
Ash Small
Sat Mar 05 2011, 09:03PM
In your first post you mention 'diode split secondary'. Surely this means the output won't be a damped oscillation? (output can't go negative)
If I=V/R, the output through a resistor will still be a spike. It won't tail off gradually (unless you have a capacitor in parallel with the resistor)....or am I missing something?
Sat Mar 05 2011, 09:16PM
Ash Small wrote ...
1299025835 2431 FT1630 Hr7964
in this pic there are 3 diodes in series with 3 coils...isnt this how modern flybacks are made, to reduce insulation demands?
Ash Small
Sat Mar 05 2011, 09:21PM
Yes...but the diodes prevent the output going negative, so the output can't oscillate. (at least as I understand it)
