  • Guests: 56
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
07/27 DaiKen (69)
Cheap, Safe, But Slow Etching Solution.
Thu Mar 03 2011, 03:09PM Print
I caught this link on Reddit this morning, and I'll definitely be trying it out.
White vinegar, OTC Hydrogen Peroxide, and salt to etch PCBs. It's a slow process, but I'm thinking with a couple tweaks you could end up with a relatively fast, reliable, completely safe etching solution for under $25/gallon.
-Dave
James
Fri Mar 04 2011, 09:31PM
HCL + H2O2 is even cheaper, and a lot faster. I paid $9 for a gallon of acid and $3 for a bottle of 12% peroxide. I used about half a quart of acid and am still using the cupric chloride that eventually resulted. Add a teaspoon of acid and a capful of peroxide every so often as the stuff starts to slow down. I've etched dozens of boards and am still using the same batch.
Sat Mar 05 2011, 05:26AM
Yeah, there are cheaper alternatives, and faster alternatives, but few that you can quite literally safely drink (not after etching, mind you). That's one of the biggest issues I have with etching boards is disposing of the waste.
-Dave
dmg
Sat Mar 05 2011, 05:37AM
Ill be trying this out too.
I have a few litters of used/spent ferric chloride in storage, just because I have no where to dump it at the moment.
It will be nice to have something that is easier to dispose of.
Sat Mar 05 2011, 09:53PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
GBD wrote ...
Surely if it's only a few litres you can simply heavily dilute it with water and chuck it down the drain. If you're worried about that then mix it with sodium carbonate (washing soda) Link2 , wait till it sets to a solid lump and throw it in the bin.
Martin.
dmg
Sat Mar 05 2011, 10:46PM
I just dont want my own ass in trouble if it damages something when I dump it down somewhere.
I guess Ill keep em around.. I might find a use for it one day.
