  • Guests: 55
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
SCR driven electric locomotive and power factor
hsieh
Wed Mar 02 2011, 01:24AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I once read that SOME electric locomotive is control it's power using SCR like components, similar to a dimmer.And I also read that dimmers causes power factor problems because it control power by deforming AC waveform. Link2 Link2
So I'm curious about that since electric locomotives consume relatively large amount of electricity, will SCR controlled electric locomotive do any harm to the power grid? If the answer is yes, how was this problem solved?
thanks
Wed Mar 02 2011, 09:22AM
Well, a locomotive might look big, but they are small compared to a national power grid. A really big one might consume 5MW at full power, but a typical power station is 2GW, and a national grid maybe 20 or 50GW.
However, the dirty current waveform of SCR traction does cause problems. It can make telephone lines near the railway unusable, if not dangerous. Here is a nice paper from Bruel & Kjaer that explains the issues. Link2
Locomotives typically use two stacked SCR bridges to improve power factor at low speeds, and there are balancing transformers by the trackside to confine ground currents to the same section of track that the train is on.
Modern electric trains have abandoned SCRs and use induction motors driven by IGBT inverters with active power factor correction. The current drawn from the overhead wires is at almost unity power factor, but still contains a fair amount of "inverter whine".
hsieh
Wed Mar 02 2011, 12:17PM
I ask this question because in the place I live,there is still tens,if not hundreds of relatively old electric locomotive using SCR .And I live near a railway.I see trains passing by very very frequently.There might be hundreds of trains running at the same time.
But by some simple calculation,I know that hundreds of trains may only consume a small percentage of electric energy in the national power grid.
