  • Guests: 31
Will (38)
Arlecchino (41)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
DLP lamp ballast
haxor5354
Sun Feb 27 2011, 04:52PM Print
does anyone know how to properly drive a DLP lamp? wikipedia says 60 volts to sustain the arc once the arc is started Link2
but with how much current?
I salvaged a DLP tv yesterday and tested the lamp with a flyback transformer, and it seems like it still works. but the ballast unit needs external control to turn it on.
so now im thinking of making my own ballast. any ideas of how limit current so the lamp won't explode. and also how much current would i need?
Adam Munich
Sun Feb 27 2011, 09:34PM
Well different lamps require different voltages and currents. What lamp is it?
haxor5354
Mon Feb 28 2011, 12:28AM
its a RCA265866.
most generic bulbs r rated over 100 watts, so i guess 1 amp at 60 volts wont do much harm
lightlinked
Tue Mar 01 2011, 11:59AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
you could probably get a cheap chinese UHP (Phillips UHP is a brand name for mercury arc lamp projector bulbs, UHP is like saying Kleenex for a projector lamp) ballast for cheap. there are also many people who grind out their dead bulbs, leaving the dichoric reflector, replacing them with the bare lamp, from china, and cementing them in with high temperature cement.
James
Tue Mar 01 2011, 05:05PM
Often times external control is nothing more than an enable line that needs to be pulled logic low or high to turn on the ballast. There are also some status lines that the controller can check to tell what the ballast is doing. I strongly recommend using a proper ballast, these lamps operate at very high pressure and often fail violently. Take care as they produce a lot of UV too, do not operate without a glass shield.
ConKbot of Doom
Tue Mar 01 2011, 05:36PM
James wrote ...
+1 on just looking for enable lines. Look for optocouplers for inputs/outputs. Ive seen a guy get a ballast running by shorting the transistor side of the optoisolaters for the enable inputs. (For a spot lamp, on the currently down candlepowerforums)
mikeselectricstuff
Wed Mar 02 2011, 01:40AM
I've played with these a while ago from a projector.
The enable was somewhat more than a simple enable line - it was via an optoisolator, and it needed a continuous stream of data. I'm guessing this is a safety feature to shut down the lamp to avoid a fire if the fan stops or the main control CPU crashes.
Attatched is some PIC code I used with a ballast PCB marked "Osram VIP" - don't recall the projector make.
Some more info on pinouts etc. here : Link2
Protocol & lamp-start info : Link2
Commands : Link2 and Link2
Note these lamps are quite scary - tons of possibly eye-hazardous UV and need continuous high airflow. The light output from them can melt the plastic of a fan placed too close (guess how I know!). If you have the rest of the projector I'd suggest trying to preserve the cooling parts.
I suspect these lamps may be hard to drive judging by the amount of electronics on the ballast Link2
I think their characteristics change significantly during warmup - the light output certainly does - when they first fire they look like a dichroic halogen, then a few secs later WHOA amazed shades as they go in to death-star mode..!
mikeselectricstuff
Wed Mar 02 2011, 01:50AM
Attachment as mentioned above- wasn't an allowed type so disappeared..
]viplamp_asm.txt[/file]
mikeselectricstuff
Wed Mar 02 2011, 01:56AM
Oops - just noticed the above source needs this macro file - can't see any way to add attatchments to a post - mods feel free to merge posts!
]mymacros_inc.txt[/file]
Adam Munich
Wed Mar 02 2011, 02:40AM
Any tips on finding one of these TVs? I've taken apart about 5 CRT projection screens but no DLP ones and I'd love to play with all the optics in one.
