  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
LC meter testing
Adam Munich
Fri Feb 25 2011, 08:39PM Print
I got my LC meter today!
(after like a month mistrust)
Overall it's a really well built circuit board. So ratty edges, well done solder joints but with a little bit of flux here and there (hand soldered). The LCD is nice and bright and it's a standard 16 pin one, so you can replace it with any color you choose (connected via headers).
1298666317 2893 FT0 Dsc09728
And now, the measurement tests:
A 330pF silver mica capacitor:
1298665647 2893 FT0 Dsc09718
A 100mH inductor.
1298665813 2893 FT0 Dsc09720
A 2.5mH inductor
1298666083 2893 FT0 Dsc09721
A 12H inductor
1298666221 2893 FT0 Dsc09724
A 150uF capacitor.
1298666250 2893 FT0 Dsc09725
An 8pF capacitor.
1298666287 2893 FT0 Dsc09729
I definitely got my money's worth.
Fri Feb 25 2011, 10:12PM
Find out the waveform and Vrms and freq used for you pF and mF measurements, thell be different and theyll matter.
Same goes for your uH and H mesurements the inductance measurements are always more iffy then the cap ones.
With the kind of HV and SMPS's you and i make, these details can become decisive in figuring out why something does or doesnt work.
These are great meters, way better than calculating and dimension math crap. so long as you know thier limitations, and do not expect better than what they are credible for. ( X.X pF is credible, X.XX is not )
Some of the internet purchased ones have sig figs that are not justified, thier just meaningless conversion remenants.
Adam Munich
Sat Feb 26 2011, 04:00AM
Measuring C gives a nice clean sine wave.
1298692756 2893 FT109592 Dsc09735
Measuring L gives a dirty wave, but it's still a sine.
1298692737 2893 FT109592 Dsc09736
All the measurements are on the DSO's screen. The frequency depends on the thing being measured; smaller values give a higher frequency.
Sat Feb 26 2011, 06:30AM
let me post my BK manual.
Adam Munich
Sat Feb 26 2011, 07:48AM
I wish I had something to compare this to. I think the significant digits are in fact significant and not just random numbers. I say this because I made an air core inductor and slowly introduced some iron into it, and the digits climbed just as they should have.
9.132
9.133
9.134
9.135
etc...
Sat Feb 26 2011, 08:23AM
Grenadier wrote ...
9.132
9.133
9.134
9.135
etc...
what are the labels fro the units?
Adam Munich
Sat Feb 26 2011, 02:23PM
It was microHenries.
Sat Feb 26 2011, 07:08PM
Good stuff! That looks like a handy instrument to have around. I'm impressed that it manages to measure such a wide range.
You could check your inductors by hooking them up to some known capacitors, and using a signal generator (if you have one around) to find the resonant frequency. Then from that you can calculate the inductance.
It wouldn't surprise me if the 12H one was really 12.49H. But when measuring iron-cored coils, remember the inductance you see depends on the frequency and voltage you use to measure it, so you can get any answer you want.
Sat Feb 26 2011, 08:05PM
How much did it cost you? Looks like it has a good measuring range at any rate! For the last few years now I've been using an LCF meter I made myself, and it hasn't disappointed yet. Link2 Does yours go up to 30000µF too? tongue
Adam Munich
Sat Feb 26 2011, 09:13PM
I bought it on ebay for $38. Link2
It maxes out at 100,000uF.
