  • Guests: 43
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Circuit help
jmg
Thu Feb 24 2011, 10:26PM Print
jmg Registered Member #3713 Joined: Thu Feb 24 2011, 10:15PM
Hey, I know this is probably going to be an extremely simple question, but I'm new to electronics and still learning.
I have this circuit to run a fan off of 2 9v batteries. I want to run two fans off of that one switch, but I don't really know what adjustments to make to the circuit. I know I would need more batteries, and I assume I'd need another voltage regulator, but I don't know how I'd hook it up. Would I just put the other regulator in series with the first and run the new batteries to it? and then that to the new fan? I apologize for the noobish question but as I said, I'm pretty new to electronics.
Final
doctor electrons
Thu Feb 24 2011, 10:34PM
Make that same circuit again and use a double pole double throw switch. Then
you can run them both with one switch and you wont have to mess with the circuit.
Inducktion
Thu Feb 24 2011, 11:01PM
IF you're trying to run two fans off the one circuit, just put the fans in parallel with eachother. They'll still need the same voltage , 12 volts each, but will use a little more current, about double if they're the same exact fans.
Coronafix
Thu Feb 24 2011, 11:07PM
Is the regulator needed? You could just use a 12V battery and put the two fans in parallel. Two fans and a switch.
jmg
Fri Feb 25 2011, 12:46AM
Ok, I'll just wire the fans in parallel and see how it works.
Thanks guys.
