  • Guests: 66
Capacitor Charger Find!
guitarlord66
Wed Feb 23 2011, 01:08PM Print
guitarlord66 Registered Member #1805 Joined: Sat Nov 08 2008, 06:29AM
How has no one else found this? I was searching the net and came across it
It states in the Description "A typical application can charge a 1000μF capacitor to 500V in less than one second."
That sounds really good to me...
What are other people opinions on this? It seems to good to be true...
EDIT! I found more this chip is smaller and says it "Charges 220µF to 320V in 3.7 Seconds from 5V"
The main reason is because I found this TINY 1:12 SMT Flyback Transformer thats supposed to go with the above circuit
MArked One
Thu Feb 24 2011, 07:29PM
MArked One Registered Member #3688 Joined: Mon Feb 14 2011, 07:39PM
I have just ordered two samples, will test out and tell you about it
Turkey9
Thu Feb 24 2011, 11:46PM
I think the 1000 uF in under a second is with this chip driving an external MOSFET witch isn't that amazing. The great thing is, however, that it is all integrated into a single package. There are a few of these controllers out there. They're mostly designed for use in charging a digital camera flash.
guitarlord66
Fri Feb 25 2011, 12:36AM
MArked One: If you get them I'd love to hear how they go :)
500v 1000uf in under a second is crazy fast to me :S and the size of the flybacks is amazing, maybe I'm just not as experienced with this stuff though...
Sat Feb 26 2011, 07:09AM
I've done 2 charger circuits using Linear Tech ICs, I used the LT3750 and LT3468. Another Mantis has also made a succesful circuit using the LT3750 here: Link2 along with my fail. Robert Wilsford has used the LT3751 in this coilgun: Link2
Note that the second charger isn't much faster than a DCC (Disposable Camera Circuit) Although it is almost definitely faster. Also the IC is very small and difficult to solder by hand
haxor5354
Sat Feb 26 2011, 05:07PM
why not just coil your own flyback transformer to have a 400v secondary and drive it with a mini ZVS flyback driver?
Sun Feb 27 2011, 03:18PM
why not build a microprocessor controlled 3-axis image recognition, targeting and aiming system while you're at it, too?
The easiest and fastest charging system is a cheap 110v-to-220v step-up transformer and diode bridge. Connect these two parts, plug it in the wall and you're done.
Cheers, Barry
Why is facebook teaching us vandalism, I mean, writing on walls?
guitarlord66
Sun Feb 27 2011, 11:31PM
Ok guys it was just a find :)
I'm going to try making a ZVS Flyback charger once I get some money to order the parts or maybe a boost converter first, I need to learn how to make circuits and not sure which to start with. I got plenty of flybacks and already removed the core from one without much damage.
I found this thinking it looked like a really fast charge thats all, I guess I was wrong.
Barry: I've only made portable chargers, and I live in Australia, our wall outlet is 240volts. So I'll just stick with portable :)
